Page 3 of 11 FirstFirst 1234567891011 LastLast
Results 21 to 30 of 104
Thread: Gas Price DigitalMod
  1. #21
    Maximum Bitrate Meatballman's Avatar
    Jul 1999
    Hartsville, SC
    I tried to use the mod serveral times during my trip. While moving, Streetdeck would not allow me to open the mod at all. I could not open the weather mod either. When stopped, it still gave me the gas prices for Kansas City, even when the weather mod returned the correct zip code. The dumb thing is, I was the passenger, and there was no way to bypass the "it's not safe to do this while moving" stuff. Very annoying.
  2. #22
    Sep 2005
    One thing i noticed was that if you are in the gas module when the car has stopped and you start driving, the system will not kick you out of the module.
    I wish there was a way to disable this. I will try creating a button from the front module to call the digitalmod. Maybe that would do the trick.
    I am on my final stages of another version of this, that will allow users to manually enter zipcodes as well as get zipcode from the gps module. This new version also has preferences for the user to select the type of gas to display.
    Stay tuned. hoping this version works better.
  3. #23
    Constant Bitrate sharpmat007's Avatar
    Nov 2006
    Washington, DC
    As far as the zipcode goes...if you are going to allow manually entering, can you have it keep the last manually entered zipcode or be able to set a default zip code?
    Mitsubishi Eclipse 2006 GT
    Infill T3 running StreetDeck
  4. #24
    Sep 2005
    New version of GPS gas price
    This version allows the user to manually enter zipcodes. Users also have the option to choose the type of gas to display as well as whether they want a voice prompt.
    I cannot attach the new version because the size is larger than 200kb. so i'll have to attach it in the wiki
  5. #25
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    not there when u try to dl
  6. #26
    Low Bitrate EvilLawnGnome's Avatar
    Feb 2006
    Louisville, KY
    I can't find the page on the wiki. Is it uploaded yet?
    Build Two:
    Planning: [==========]100%
    Purchasing: [=====---------]50% (Car just got broken into)
    Design: [=======-----]70% (Building a false panel to cover up my goodies)
    Install: [======--------]600% (Need to replace screen and beisel)
  7. #27
    Sep 2005
    Quote Originally Posted by tn6478 View Post
    Quote Originally Posted by EvilLawnGnome View Post
    Had a bit of a problem ftping it. incorrect size.
    Try it now. it should work
    wiki
  8. #28
    Feb 2006
    Louisville, KY
    I haven't been able to get this to work for me. When ever I try to search for gas prices in my zip code, it kicks me out of the Mod with an error message. It is something to the extent of: ActiveX cannot create object Get_Gas_Price(). Any ideas?
    Build Two:
  9. #29
    Nov 2006
    Washington, DC
    Have the same issue when manually entering zipcode.
    ~edit~
    I had the problem. I read the beginning of the post regarding registering the two dll's and it fixed the problem. If all else fails RTFP.
  10. #30
    Jul 1999
    Hartsville, SC
    Another shot
    I'm going to give this another try. In a week and a half I'll be driving from South Carolina to Oklahoma and back to help a friend move. I should have plenty of opportunity to use this.
    It should be easier since I now know how to run in testmode. How useless is this feature if you have to wait until you've come to a complete stop, most likely at a gas station, before trying to find a cheap gas station?
    What would make it really useful (but I imagine would be terribly difficult to do) would be to be able to specify only gas stations within x miles of your current route.
