Sorry...I didn't mean to imply that the module is useless. The artificial restriction in Streetdeck is the annoyance. I'm assuming you have the Module_IsSafe code in there?
let me know how useable it is. Currently, with having to completely stop before using a digitalmod is a limitation on streetdeck and not on my digimod.
The only way to have to have the digimod running while driving is to have the module loaded before driving. If anyone knows a way to bypass this, let me know and i'll add it to the digimod.
its all good. I am looking for constructive critism to make the module more user friendly and usable. So feel free to pound on it and give me your feedbacks.
By the way, I am using the Is_Safe method. One thing I need to try is modify my skin to create a button that calls the digimod directly in stead of through the digimod module. I believe the restriction is in the digimod module itself.
if that works, that could be our only solution unless chuck knows otherwise.
The restriction is in SD and not the module. Even if you pull it directly the way I do with a button on the main screen it still wont do it. You have to be park or stop
sorry if i missed this: do you have to be parked or stopped even if you're running -testmode?
no
Jan Bennett
I've downloaded the current version and everytime I try and manually add my zipcode SD will crash. Anyone else having this problem? Does the new version still get the prices from the navigation automagically? I haven't been able to use this and it would be very useful with gas being almost 4 bucks a gallon here in Cali.
And me.
Build Two:
Planning: [==========]100%
Purchasing: [=====---------]50% (Car just got broken into)
Design: [=======-----]70% (Building a false panel to cover up my goodies)
Install: [======--------]600% (Need to replace screen and beisel)
