Page 9 of 11 FirstFirst 1234567891011 LastLast
Results 81 to 90 of 104
Thread: Gas Price DigitalMod
  1. #81
    SD beats everything. So there. danielkh's Avatar
    Sep 2007
    Beaverton, Oregon, United States
    Quote Originally Posted by bembowe View Post
    If anyone knows of a good site to get gas prices per zipcode, send them over to me.
    thanks
    Done.....will search after work today!
    My opinion is my own.
  2. #82
    Sep 2007
  3. #83
    Sep 2005
    I like the msn gas prices. so i'll look into using that.
    thanks
  4. #84
    Sep 2007
    thanks
    That was my favorite too. And guessing it would be the most accurate. Need anything else, let me know!
  5. #85
    Variable Bitrate JasonMK's Avatar
    Jun 2007
    Annapolis, MD
    Any update on re-releasing this digimod? I miss having it, it is definately one of the things 1st timers are most impressed about when I show them the carputer.
    _______________________________________________
    All installed, and ready for visitors. Infill G4 in a 2007 Saturn VUE
  6. #86
    Jun 2006
    Ventura County
    The big issue that I've seen so far on this is that most of the other sites use graphics in place of text for the fuel cost. So instead of showing $4.25 in text form it's a graphic with random characters in the filename. I'm guessing to prevent other people from extracting the gas prices from the page directly.
  7. #87
    Sep 2005
    new dll
    Ok guys,
    I went ahead and redeveloped the GasPriceDll to work with the new format. I guess this is the only way I can make this work until I have a better feeding mechanism.
    Anyways, I just tested the dll only not the digitmod. Am able to reproduce the same xml file required for the digitmod to retrieve data so I dont see why this shouldnt work.
    I need some of you to test the new dll from the digimod. I cant right now as why development pc doesnt have the navi part of streetdeck install so I would have to wait till I get home to test it.
    All you need to do is replace the GasPriceDLL.dll associated with digimod ( located Streetdeck\Scripts\{3D8C3A42-34D7-480C-920F-7CC83363838F}\COM) with the attached dll (unzip it first ).
    Also register the dll using the following command within the same folder above in the command prompt
    regsvr32 "GasPriceDLL.dll"
    Let me know how this works. I will test it when I get home and create a new digimod if it works.
    Attached Files Attached Files
  8. #88
    Jun 2006
    Ventura County
    Great! As soon as this looks good, let's get this posted in the Approved Digital Mods section of the Streetdeck forum!
  9. #89
    Sep 2005
    ok, finally tested it and it worked so here is the new digimod
    note: upon initial install, i realized that I had to go to the preference page of this digimod and reselect the type of gas to display, otherwise it displays the cached value. this only occurs the first time because of the old version I had installed.
  10. #90
    Jun 2007
    Annapolis, MD
    Thanks many times over, I'll give it a whirl in the morning on the way to fill up the car
