Results 1 to 10 of 13
Thread: Hqct .net Addin!
    Aug 2006
    Hqct .net Addin!
    Hello everybody! I'm working on a .net addin using the .net HQCT project. I have no idea if this will even work (as I do not have streetdeck installed on my desktop nor do i have an hqct on my desktop) but I made a simple little addin. I would appreciate it if someone could try this out and let me know if it even works or whatever... thanks.
    UPDATE: I went ahead and bought streetdeck, took the HQCT out of my car and hooked it up to my desktop, worked on the plugin, and it WORKS! You can try it out yourself by downloading it here: http://www.pogi.org/HQCT%20Addin.sdz
    If it gets renamed to .zip just rename it back to .sdz. Also, after you install it, you have to manually register the .dll's by using RegAsm.exe with the /codebase parameter. If someone can post sample ComRegisterFunction code to register extra DLL's that would be great. THanks to everybody that worked on the C# implementation of the HQCT stuff.
    Elsewhere
    You know that you can download the trial for 30 days...
    It's the same as the developer edition.
    How about the Wiki?
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    oh man I am gonna have to go buy a HQCT radio now....
    what are the chances that streetdeck will incorporate digitalmods straight into the app if it becomes a popular digitalmod?
    _
    Mar 2004
    Little Elm, Texas
    kudos!
    If I had a HQCT, I'd jump on it. Might have to take the plunge on it.
    As for a digimod being integrated, I'm not sure what the method for determining this is.
    Jan Bennett
    Aug 2006
    you can change your skin to make the digital mod right on the front screen, just as if it was integrated. I'm using GPL'd stuff (the C# HQCT project) so I dont think this will ever be fully "integrated"... but it is really easy to change your skin to make the "radio" button load the digitalmod instead of the normal radio.
    Aug 2004
    Pearland
    sounds like I finally need to watch that skinning video
    Aug 2006
    Oh yea, one more thing... I think this will also work with the HQCTe.... which might be what the streetdeck folks have been waiting for. Supposedly its coming out in the next week or so (at least the first 10 units)! Exciting times..
    Aug 2006
    Update (read first post)
    Constant Bitrate jAyRoCkS24r's Avatar
    Aug 2006
    Jersey
    Does your hcqt plugin support any rds rdbs support? I tried installing sdz package but got an error. I was traveling for work this week and had a car with rdbs and it makes FM much more enjoyable and friendly to a carPC? Any information with be great!
    Engineering....Where the unknowing teach the unwilling the unnecessary.
    Mar 2007
    Östersund, Sweden
    Addin problem
    Hi. great job with the plugin.
    I'm having a bit of trouble though...
    after installing and manually regging the dll's my SD wont start
    resulting in an error stating that button.misc.nofocus.png is missing
    which of course it is....nowhere to be found. deleting the folder in scripts
    makes SD start again.
    any ideas?
    /Markus
  1. sendMessage from a .Net App
    By ruairi in forum Road Runner
    Last Post: 09-30-2007, 01:32 PM
  2. VoomPC Ampie Case and HQCT module
    By mcfennek in forum General Hardware Discussion
    Last Post: 07-16-2006, 05:16 PM
  3. HQCT Library
    By mtrax in forum Newbie
    Last Post: 05-31-2006, 03:21 AM
  4. Error installing .Net framework 1.1.4322
    By proximo in forum WinNT Based
    Last Post: 05-19-2006, 05:07 AM
  5. Using Destinator SDK with .NET
    By BrainCore in forum Map Monkey
    Last Post: 05-08-2006, 05:53 AM
