Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Data from the car engine
    Feb 2002
    Miami, Fl
    Question Data from the car engine
    Is it possible to capture data from the engine, for example speed, rpm, oil pressure, etc? And then interface it with our carputers?
    Aug 1999
    Washington D.C.
    Yes, using either OBD or OBD-II depending on the age of your car.
    What would you want to do with that data?
    Jun 2002
    Rochester, NY
    I would want to display it on my lcd screen in my car, maybe log some info...mostly just display. Anyone have any way of interfacing the obd 2 connector with a parralell or serial port?
    Shuttle SV-24 (Plexiglass case)
    5 Gig Laptop HD (Now Dead)
    256 Ram
    466 Celeron (1 Gig Toasted)
    7" 16:9 touchscreen LCD
    Firewire Slot Load DVD
    700W Inverter (Power to spare)
    Monster Cap
    Sproggy Shutdown Controller
    Custom Fiberglass Console (Idea Junked)
    Still Need: GPS, and some kick a@# software!
    Aug 1999
    Washington D.C.
    You need a protocol converter that connects to serial port of your computer.
    The one I have is from this guy Dan Harrison, http://www.ghg.net/dharrison/obdscan.html I won't recommend buying that guys product. He is an ******* and never replied to any of my emails or phone calls regarding problems with his buggy software.
    I wrote my own interface software in visual basic because his was so bad and I was looking to export those variables on something like and LCD screen so I could keep an eye on things.
    Jun 2002
    Rochester, NY
    Do you have any pictures of your software interface? If so...please post! Am very intrested in your setup and im sure others are. If you would not mind showing us how far you have gotten with the external lcd idea, it would be really appreciated.
    256 Ram
    Monster Cap
    Feb 2002
    Miami, Fl
    Hey thanks for the infomation. I was planning on writing software that would turn the data into a nice grapical format. As well as logging. How do you find out if your car is OBD or OBD-II?
    Aug 1999
    Washington D.C.
    If your car is a 1996 or newer it uses OBD-II. OBD-I was used in cars before 1996, I don't know how far it goes back.
    In my little program I'm trying to find a way to calculate real time miles per gallon. I understand it's some relationship between engine load and the mass airflow senor. But I have no idea the formula used to calculate it. Can anyone offer insight?
    Feb 2002
    Miami, Fl
    Does anyone know of a cheap source for the interface to the computer. It would have to be OBD-II generic. Thanks
    Variable Bitrate spud42's Avatar
    Oct 1999
    brisbane,qld,australia
    http://www.obdii.com/
    try here as a start . there are others around if you search . if you find a circuit or more info please share ;-))
    Volvo V40 Phase 2 2002. T4 turbo upgrade.... currently no mp3 or carputer..... researching options
    Aug 1999
    Washington D.C.
    Try http://www.andywhittaker.com/ecu/obdii_hardware.htm
    or
    http://www.obd-2.com
    both a pretty cheep, one offers student discounts.
