Have you checked your installation disk for the driver?
You should contact the seller and inquire which USB chipset your unit is using.
Hi, I just installed my OBDII cable, but i can not find the drivers anywhere...
it's an ELMscan 327...
I searched for the drivers (on scantool.net) but the ones I downloaded from there don't have a setup file included, and when i let windows search the drivers in the folder I extracted the files to, windows cannot find any...
I'm using windows XP
can anyone help me?
ps: it's an elmscan with USB
Greetz
Dj NRG
I don't have the cd no more (or can not find it anymore) so I will have to download the drivers somewhere...
i think i may have found them... will try to install them tomorrow..
Greetz
Dj NRG
usually, when you find a solution to an issue, posting that solution is generally beneficial, especially for the other members of the fourm. For instance, this guy could have used the link: http://www.mp3car.com/vbulletin/1160678-post13.html
Jan Bennett
ive got the drivers but it still doesnt wrk![]()
ive taken winzip and acrobat reader out to save space on the file
Ive also got it workin
it was not workin because my touchscreen was not compatible in the scantool program so i used keyboard shortcuts.. hopefully a mouse would work better than a touchscreen.
thx!
will try to get it to work once i've got some time
Greetz
Dj NRG
how did you get the drivers to install i can't seem to figure it out.
