Results 1 to 10 of 16
Thread: Data Logging - Vehicle Sensors
    Registered User cliffloehr's Avatar
    May 2006
    Decatur, AL
    Has anyone got a good (inexpensive) hardware solution (home made - or purchased) to connect the CarPC's serial port to the 0-5vdc output of an after-market w/b O2 sensor?
    I've been a geek for many years, but after getting a Mustang to satisfy my mid-life-crisis, I'd like to use the CarPC project to do some interactive data logging and tunning.
    I'm thinking the data logging device could interface more than one sensor... ...outside & inside temp is all i can think of right now.
    The OBDII device (COM1) and the TwEECer/RT (USB) can access all the other vehicle data.
    PPE
    PPE is offline
    PPE's Avatar
    Mar 2006
    I don't know how inexpensive you are looking to go, but our PCMSCAN software supports several types (Innovate, AEM, TechEdge) of after-market wideband sensors. You simply connect the OBD-II plug into one of your serial ports (or USB ports) and the wideband's serial output into another serial port. Then configure PCMSCAN to connect on both ports (this is very easy to do), and PCMSCAN will do the data logging from both ports simultaneously.
    After you have the data logging set up, you can view the wideband data along side the engine data in the dashboards, tables, graphs, or maps in PCMSCAN.
    -Brian
    Brian @ Palmer Performance Engineering, Inc.
    http://www.palmerperformance.com
    May 2006
    Decatur, AL
    Thanks for the link, I'll keep it in mind for when I have everything all hooked up. But, the w/b O2 sensor does not have a serial out... that is the whole point of this thread. It has a 0-1v out to replace the original narrow band sensor and a 0-5v (wide band) output (two wires)
    Mar 2007
    If i'm not mistaken there's a thread on hackaday.com but it might be on rx7club... about a board that converts the 0-5v of a wideband out to a more useful format. If you're into carpc's why don't you megasquirt your mustang and hook it up to your carpc? custom 0-5v in, datalogging, DIY.
    btw there's no use in datalogging your wideband if you don't have other useful things to monitor like TPS & RPM, etc.
    May 2006
    Decatur, AL
    Quote Originally Posted by CapnBoost View Post
    The TwEECer/RT does the data logging for everything but the w/b O2 so that should be good.
    Thanks for the hackaday.com link... lots of stuff to look through. I'll post the project link if i find one.
    Here is a link to the PLX w/b O2 sensor i have.
    Mar 2007
    You have to be able to line up the sensor data side by side. To have one ahead or behind will eliminate its usefulness in tuning. What is TwEECer/RT? I posted a thread on the 7 forums trying to find the discussion if it was there. there's *lots* of good stuff on hackaday even if you don't find what you're looking for.
    EDIT:
    I found the thread i was looking for: http://www.rx7club.com/showthread.ph...0&page=1&pp=15
    But it was EGT's and making them 0-5v to interface with datalogging stand-alones.
    If you want to get nerdy try to log:
    intake air temp (not as crucial on a naturally aspirated car)
    tps
    injector duty
    ignition advance/retard
    & EGT's
    if you can put those all side by side it should be a good aid in tuning.
    May 2006
    Decatur, AL
    the data logger projet is on hold while i fix another problem that poped up today. I lost 3rd and 4th gear... so theres no need to log data on a car that can't go over 30mph!
    Mar 2007
    I think this may be what you are looking for, but I donno. This is from Innovate and it connects sensors to comp and comes with datalogging software (free dl). Hopefully it'll solve your problem.
    http://www.innovatemotorsports.com/products/ssi_4.php
    Fusion Brain Creator
    Mar 2005
    There's a project in the Hardware Development subforum. one of the first few links.
    Newbie Brock's Avatar
    Apr 2007
    Michigan, USA
    Innovate is in development of an OBD2 interface. Supposed to be $149.
    It has a USB interface for monitoring and datalogging as well as serial link for
    all their other sensors (wideband, etc). It's called OpenTune (OT-1). So, all
    you would need is the OT-1 module and a wideband (or 2 for your V8). Here
    is a link with a small news blurb about it:
    http://www.innovatemotorsports.com/resources/news15.php
  1. Satellite Data? Costs?
    By PAdams in forum Wireless Communications
    Last Post: 09-19-2006, 04:03 PM
  2. Capture GPS data at the flip of a switch
    By Mr. Inquisitive in forum GPS
    Last Post: 02-02-2005, 07:06 PM
  3. Mobile video in California
    By dacndar in forum LCD/Display
    Last Post: 11-30-2004, 03:36 PM
  4. VOICES Traffic Data
    By stevieg in forum V.O.I.C.E.S
    Last Post: 05-31-2004, 09:24 PM
  5. Online Traffic Data (UK)
    By stevieg in forum Software & Software Development
    Last Post: 04-27-2004, 03:14 PM
