Results 1 to 5 of 5
Thread: OBD-II Books, PDF's, Resources
    DM2
    DM2 is offline
    Newbie DM2's Avatar
    Apr 2007
    Houston, Texas
    I’ve ordered a 2008 Ford King Ranch and am planning on installing a CarPC in it. I’m now in the research mode and was wondering if anyone out there had recommendations on books that explain OBD-II and what information is available from the vehicle via the OBD-II connector.
    I’m also interested in resources for what ever proprietary information Ford may have in their system.
    Any recommendations?
    Jul 2005
    Look at AutoEnginuity. I have their connector and OEM specific PIDs. I forget what the cost is but it seems like it maybe around $400, but they have good support for newer Fords. Ask them what they support before you buy, I got a little screwed on one of my cars because I assumed that OEM Specific PIDs were supported (2007 Cadillac CTS) but they were not.
    DM2
    DM2 is offline
    Newbie DM2's Avatar
    Apr 2007
    Houston, Texas
    Have you used this software with anyother other applications (i.e. RR)?
    I'm hoping to be able to get the extended PID's into an application that is skinable. Have you tried anything like this?
    Oct 2007
    I would also be interested in what you are doing and what you find. I have a 07 Navigator I'm putting on and want to control it via the CAN bus as well as interface other devices. Also I want to program functions using the Nav Touch Screen and or other buttons to make the lights come on/off etc. and program the OEM lights to come on with different inputs. I will gladly share any info. I find.
    Feb 2006
    Melbourne, Australia
    You can "embed" Autoenginuity in Centrafuse - I am doing that....but it is still better to run it as an external application, as you loose to much screen real estate when running a FE...
    That's my feeling - but I have resolved that issue by using a 10.4" LCD - smaller than that, and you have a problem.
    F6 Tornado Project Log ; HP Blackbird Watercooled Server
    Beta Tester for Centrafuse and 3dConnexion (No business affiliation with either)
  1. Need help to figure out OBD ii connections
    By virengoyal in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-19-2009, 06:03 AM
  2. OBD II and Citroen Xsara
    By ThePohorc in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-02-2008, 09:41 AM
  3. Confused about OBD II
    By tom2112 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-19-2007, 02:06 AM
  4. does this connector means i have obd II ? (Buick 95')
    By tomer in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 09-03-2007, 08:03 AM
  5. Where went the Guages in the OBD II plugin?
    By bns2000 in forum Centrafuse
    Last Post: 08-11-2006, 11:39 PM
