Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Turbo my RAV4, need help
  1. #11
    Jul 2007
    First of all, why??? Are you doing it to show off the PSHHHH, blow off valve or for speed? These are the only 2 reasons behind this. I have a 91 MR2 Turbo aka 3sgte that is modified and a stock 98 Toyota Rav4 and have worked on these engines for rought 6yrs. If you're looking for safety and speed, I'd recomend a V6 camry engine swap. If you really want the turbo, then do a full swap to a JDM 3sgte w/ LSD transmission.
    What ever you choose to do, good luck.
  2. #12
    Newbie Teranfirbt's Avatar
    Dec 2005
    Oregon State U!
    I know too many people who started down the turbo path using piggy back band aid systems like the e-manage, SAFC, etc and have had to stop and start from scratch with a true stand alone after their band aid couldn't tune out pinging or weirdness in the running of the engine...
    I'm currently running a Megasquirt ECU on my 22RE and it's VERY VERY happy. Tuning is easy, it's not that hard to get started, you can use factory sensors, and the best part is, you can do the ECU with a wideband O2 sensor for tuning for less than $500.
  1. GM Celta 1.4 Turbo Carputer
    By Alexandre1977 in forum Show off your project
    Last Post: 05-18-2008, 02:02 AM
  2. Alarm Wont Arm With Turbo Timer
    By mr2corydsm in forum General Hardware Discussion
    Last Post: 05-03-2007, 10:24 PM
  3. 89 Supra Turbo finished (for now)
    By drait in forum Show off your project
    Last Post: 04-16-2007, 11:38 AM
  4. Turbo noise out of your exhaust?
    By jzgt in forum Off Topic
    Last Post: 07-03-2005, 08:44 PM
  5. Turbo readouts from OBD?
    By moonshinemadnes in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 07-31-2004, 04:53 PM
