The 3SFE is the same engine that's in the N/A MR2 right? If that's the case can't you just do a OBDI swap and run a chipped ECU?
Either that or you're going to need to get either a piggyback or stand alone ecu. Don't think a regular carputer can help you out here.
LinkBack URL
About LinkBacks
and
are your best friends. They help locate info you want.
