Results 11 to 20 of 29
Thread: LF: OBD2 - Import - "Build your own kit"
  1. #11
    Apr 2002
    Rochester, NY
    my ride my team
    2001 Civic EX- lowered, 18", NOS
    12.1"touchscreen, gps, dvd, tv, fm
    NO RADIO!!!!!!!!!!!!!!!!!!!!!!!!!
  2. #12
    Low Bitrate InvisiBill's Avatar
    May 2002
    Michigan
    Originally posted by InvisiBill
    I posted a pic of a schematic for an ALDL-serial converter for my OBDI Syclone a while back. Not sure if all ODBI stuff is the same or what, but it works for me with $8 in parts. Do a search in this forum for ALDL and you should find it. My whole reason for a carputer is to run DataMaster...
    Obdii is the thread I was referring to...
  3. #13
    FLAC cproaudio's Avatar
    Aug 2002
    so cal 2 hours from everywhere
    I just got my OBD-II scan tool from Alex at www.obd-ii.com I got the Tricom which is the probably the best one they got. It works with my 97 Tacoma. Its got a digital dash display with 2 big guages and 4 smaller gauges. All 6 guages are configurable to display anything your car can send to the OBD-II port. I only plug it to test it once cuz im still putting my system together. I was able to display RPM, MPH, engine load, Air intake temp. I only messed with it for about 10 minutes. The fastest update time is 1 second. I hope the new software cuts down the update time to quarter second or at least half second. Anyway I really think it's worth the 183 I spent.
    http://www.obd-2.com/dashg.htm
    I was considering the scanner from www.autotap.com but their enhanced all in one scanner is $490. If you have an LS1 engine, their system works with the EFIlive which has a bad *** virtual dash display.
  4. #14
    Aug 2002
    oops its www.odb-2.com
  5. #15
    Sep 2002
    Cool
    Hi:
    I made my OBD-II interface on the basis of this schematics:
    http://www.planetfall.com/~jeff/obdii/
    It has been working perfectly for months...
    Regards,
  6. #16
    Jul 2002
    Mmmm... I wish that circuit would work with my Mercury Cougar!
  7. #17
    Sep 2002
    If it is OBD-II compliant, it should... But I guess it is Ford, right? And Ford has its own OBD-II implementation, isn't?
    Regards,
  8. #18
    May 2002
    You mean something like this?
    I wrote this myself to use with my Harrison R&D scanner. Let me know if you want the code. It's a little jerky because I refresh everything with each cycle. I will be fine tuning it to only refresh those things that change quickly with every cycle.
  9. #19
    Aug 2002
    longview washington
    dam thats nice would it work for my 86 s-10 blazer? wich i guess would be obd1
  10. #20
    May 2002
    Probably not. Sorry.
