Quote:
Originally posted by mxxxxxm
I'm not an expert, but I have been trying to learn more about obdi2 for some time now.
I know GM uses obdi2 and you can use any obdi2 reader as long as it has the appropriate connector. [different manufacturers use diff connectors, but many share the same one with the same pin outs]
I also know that GM has an "enhanced" obdi2, meaning in order to use the enhanced information, you need a obdi2 reader that is compatible with the enhanced info stream.
hope that clears up some, I'm still trying to find a GM enhanced reader that isnt $400.
I'm not an expert either and correct me if I'm wrong but GM is not the only one uses OBD-II. ALL cars made after Jan 96 and sold in the USA are OBD-II compliant. different manufacturers use different protocols. Thats why there are manufacturer specific readers out there. GM uses VPW. Most 96-97 Toyota also use VPW. Fords use PWM. Chrysler and most imports use ISO9141 protocol. Most 98 Toyota switch to ISO9141. You can find which protocol your car uses at
