Well guess its not ODB-II, he says it will only work on certain cars, so that means it is not obd-ii. obdii is a standard across all cars, so those makers must have had some obd-ii similar system before they had to convert.
Some info..
OBD-II is a standard, which means that Ford OBD-II is the same as Chevy OBD-II which is the same as BMW-OBD-II, which is the same as xxx OBD-II, so a scanner that is OBD-II compliant will work with any of your cars that are OBD-II compliant.
Now there are some manufacturer specific OBD-II codes and functions, but they are simply a software change, the connector, hardware, etc are the same.
OBD-I was not a standard so you need manufacturer specific hardware and software so you have to buy/build an OBD-I tool for your specific make of vehicle.
Sdelgran thank you for the link, I had not found anything cheap yet, only custom chips, or premade hardware. I will probabally place a digi-key order tomorrow.
This is what I use
http://obddiagnostics.com
I have been using this product for a while now and it works great!! ANY car I hook it up to (Ford, GM. Import) with OBD II it connects to and let's me moitor and clear engine codes. It was a cheaper alternative then going to a dealer every time my engine light came on.
All the info you can get from the site. The way I did it was to buy the printer circuit board and the partial parts kit and buy the rest at your local electronics store. You can also get a case to cover it all up.
Hope it helps
Stibby
[QUOTE]Originally posted by eugenen
[B]Some info..
I dont think so. My 97 Toyota uses VPW OBD-II (96-97 Toyota). GM also uses VPW. Ford uses PWM. Chrysler uses ISO9141. Imports also uses ISO9141 (98-UP Toyota). If the only difference between all 3 specs is software then why do Autotap.com and OBD-2.com sell vehicle specific scanners? Even Sears sell GM only scanners and Ford only scanners. OBD-2.com has only 1 software for all their scanners. If what youre saying is true then why do OBD-2.com has many different scanners and only 1 software?
I'm not an expert, but I have been trying to learn more about obdi2 for some time now.
I know GM uses obdi2 and you can use any obdi2 reader as long as it has the appropriate connector. [different manufacturers use diff connectors, but many share the same one with the same pin outs]
I also know that GM has an "enhanced" obdi2, meaning in order to use the enhanced information, you need a obdi2 reader that is compatible with the enhanced info stream.
hope that clears up some, I'm still trying to find a GM enhanced reader that isnt $400.
I'm not an expert either and correct me if I'm wrong but GM is not the only one uses OBD-II. ALL cars made after Jan 96 and sold in the USA are OBD-II compliant. different manufacturers use different protocols. Thats why there are manufacturer specific readers out there. GM uses VPW. Most 96-97 Toyota also use VPW. Fords use PWM. Chrysler and most imports use ISO9141 protocol. Most 98 Toyota switch to ISO9141. You can find which protocol your car uses at http://www.obd-2.com/dlc.html As for the OBD-II connectors, they ALL uses the same 18 pin connecter. The pin positions are different from protocol to protocol. Thats why there are readers that will read all 3 protocols. I bought the all in one reader because my 97 Tacoma uses VPW and my Sieanna uses ISO9141. I was able to plug my reader in my friends' 99 Ranger and 98 Chevy silverado. You can get GM enhanced reader for less than $300 at www.autotap.com They also have a version that has LS1 engine management.Originally posted by mxxxxxm
Originally posted by cproaudio
I'm not an expert either and correct me if I'm wrong but GM is not the only one uses OBD-II. ALL cars made after Jan 96 and sold in the USA are OBD-II compliant. different manufacturers use different protocols. Thats why there are manufacturer specific readers out there. GM uses VPW. Most 96-97 Toyota also use VPW. Fords use PWM. Chrysler and most imports use ISO9141 protocol. Most 98 Toyota switch to ISO9141. You can find which protocol your car uses at http://www.obd-2.com/dlc.html As for the OBD-II connectors, they ALL uses the same 18 pin connecter. The pin positions are different from protocol to protocol. Thats why there are readers that will read all 3 protocols. I bought the all in one reader because my 97 Tacoma uses VPW and my Sieanna uses ISO9141. I was able to plug my reader in my friends' 99 Ranger and 98 Chevy silverado. You can get GM enhanced reader for less than $300 at www.autotap.com They also have a version that has LS1 engine management.![]()
This is my understanding as well. Also, someone correct me if im wrong, but the "standard" for obd-II is in the hardware side of it, which is why the software/protocol differs (the gov said you will use this connector, and make it so that you can monitor X, Y, and Z hardware). Some scan tools have been writtent to understand any of the protocols or sub protocols (differnt years have different capabilities, im most familiar with the audi obd-ii, which has evolved since 96, so that you cant use a older scan tool with the newer (01+) cars), but the cheaper ones only do a specific protocol/sub protocol. And OBD-I is even less of a standard, its really a loose conglomoration of cars that had basic onboard diagnostics. No two will be alike (in terms of two different makes).
-Nick
_____________________________
Monthly MP3Car Chicago Meets
www.mp3vw.com Last updated: 07/07/2008
Just curious. For those who has the OBD-I or II, Please list year make model engine and engine load at idol. I have a 97 Toyota Tacoma 2WD V6. Engine load at idol is 17%.
17% seems a bit high for an idle.
My '97 Chevy Malibu V6 3.1L runs at about 3% load idling @ 500 RPMs. If I turn on the a/c it might go up to 4%. Even when flooring it going up a big hill I can't seem to get it to go above 80% @ 4500 RPMs.
