Results 1 to 3 of 3
Thread: Direction needed
    Jun 2007
    Denver Colorado
    Direction needed
    Hi, I am a newb here and need some help. I would like to install a engine monitoring system and not sure what I should be looking for. I have a Fujitsu Tablet that I will be using for GPS, that has W2K, 80 GB HD and 192 of RAM. I have a non OBll car, 8 cylinder, fuel injected with a Motronic DME. It seems to me that I need something to collect the data and convert it into a form that a software program would understand and display. I would also like to get the fault codes from the DME. I should also metion that in addition to the DME, the car has a additional brain that manages the engine.
    Any help would be greatly appreciated,
    Terry
    Jun 2007
    Denver Colorado
    Is thier any help out there?
    Low Bitrate sinclairvital's Avatar
    Jun 2005
    Start by looking at the protocol required to access the diagnostics from your DME / car "brain", then the hardware required to interface to that. It may already be available "off the shelf".
    Sinclair
    http://www.kbmsystems.net
    http://www.obdkey.com
  1. Needed, Last few Norwegian translations needed
    By veetid in forum Centrafuse
    Last Post: 06-13-2007, 11:55 AM
  2. Arrows on videos in direction of motion!
    By doof205 in forum Software & Software Development
    Last Post: 11-16-2005, 03:16 PM
  3. Direction Indicator for MM & FD
    By GizmoQ in forum RR Skins
    Last Post: 10-10-2005, 12:50 AM
  4. Direction Sensing Active IR Sensor Thing.
    By Mio in forum Hardware Development
    Last Post: 10-03-2005, 12:55 AM
  5. Amplifier Needed?
    By c0rrupti0n in forum Newbie
    Last Post: 03-15-2004, 04:04 AM
