need help w/ OBD1 and a mac
hello everyone,
n00b! I have two things that i would like to use together and cannot find a way to use them yet.
-the car i have is a 93 civic HB (OBD1)
-the laptop i have is mac (OS X)
my goal is to be able to connect my laptop to my 93 civic. I would like to be able to monitor my cars performance, to put it in the simplest way possible.
Is there any OBD1 software out there that is compatible with a mac?
if not, is there anything that i can do to make this work. I know of plenty of OBD11 software but of no way to use it seeing as my car has an OBD1 ecu. I would appreciate all input from u miracle workers
Have a look at EVO-SCAN, (evoscan@limitless.co.nz).
They do cables and software for pre-OBD2 Japanese, vehicles.
They may be able to help.
thnx alot, that link helps alot. hopefully il find somthing
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
