Results 1 to 3 of 3
Thread: Reading ODBII from SCT XCaliber 2
    Constant Bitrate Hessian's Avatar
    May 2007
    I have a SCT XCaliber 2 I'd like to get ODBII data from. I know there is the LiveLink (buggy) software but has anyone seen anything else. I just need some code to look at that reads speed,load,temp,fuel, etc.
    I talked to a guy at SCT and got nowhere on API docs.
    Otherwise I'll have to dig into the dlls that come with LiveLink and try and figure something out.
    VENDOR - OBDPros
    Mar 2006
    That's one of the problem with some of the hardware interfaces closed API's...
    One more reason why something like the OBDPro is better since the API is open and you can write custom software as needed.
    One though is you could install a USB spy software and see what data goes back and forth to try and reverse engineer the protocol
    Paul
    www.obdpros.com
    May 2007
    Reverse Engineer
    I hope it does not come to that. I used Reflector and I could peek into the dlls, but I've not put that much time into it yet. I'm hoping I can get some other use out of my $350 tuner. An open tool would be much easier and probably save money on the time it would take to hack the XCal.
  1. ODBII Pickup
    By Badgerboy in forum Centrafuse
    Last Post: 01-22-2007, 04:38 AM
  2. Do any front ends support ODBII adapters?
    By mattress in forum Software & Software Development
    Last Post: 08-27-2006, 12:19 AM
  3. Help prequired for reading serial port data !!
    By tolisn in forum Road Runner
    Last Post: 07-06-2005, 05:04 PM
  4. Replies: 7
    Last Post: 07-01-2005, 04:29 PM
