A little delayed, but I ran across this post searching for something else. If you're running lean on bank 2, but not on bank 1, try replacing the O2 sensor, that's the most likely culprit.
Bank 1 is before the Cat, bank 2 is after. Generally, you won't get a "lean" warning if it's the Cat, so it's probably just a bad sensor.
LinkBack URL
About LinkBacks
