Results 1 to 2 of 2
Thread: MPG & Odometer
    Aug 2007
    MPG & Odometer
    Hi I am new here.
    I have the OBDII connection. Can somebdy tell what are the string shows
    MPG(I heard some car does give MPG through OBDII connector).
    Also What are the strings for Odometer reading.
    Oct 2005
    UK
    Hi,
    MPG is a calculated field I'm afraid, if you are looking for this type of data probably best to go for a ScanGauge - they've done all of the work for you!
    Gareth
  1. OBDII / Elm MPG meter. Almost working but not quite!
    By stevieg in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-19-2008, 04:24 AM
  2. Feature Request - Realtime MPG in OBD-II
    By blckwdw in forum Centrafuse
    Last Post: 12-01-2006, 11:11 AM
  3. Where is yhe Odometer data stored?
    By paul1 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-02-2006, 06:04 PM
  4. MPG for Nissan Titan
    By plmoreau in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 09-08-2006, 08:27 AM
  5. MPG Software
    By GPSFelix in forum Software & Software Development
    Last Post: 09-04-2003, 02:43 PM
