Results 1 to 5 of 5
Thread: OBD II - Windows Mobile 5/6 - Bluetooth Solution?
    Aug 2004
    Anyone have a setup with
    - Windows Mobile 5 or 6 (Phone Maybee: square screen)
    - Bluetooth OBDII
    - OBDII Software
    I finally got rid of my old "PDA" and got a verizon palm Treo w/ pda all in one..
    I have bluetooth GPS up and running and I am interested in some sort of solution for OBD II vehicle stats. What software to run... ANY SUGGESTIONS?
    I have seen the bluetooth adapters at scantool.net and digimoto.com (looks nice) but I cant seem to find anyone using any of these solutions... ANY SUGGESTIONS???
    Aug 2007
    Detroit, MI
    The Cardix programming environment (see a nearby thread entitled "An easier way to write software that interacts with your vehicle" for more info) runs on the .NET Compact Framework, so this would enable you to write an application that runs on Windows Mobile and has ready access to OBD data. I know there are at least a few vehicle connection devices which provide Bluetooth connectivity. One which I have worked with a bit is the OBDKey device (www.obdkey.com) and Cardix support for that device is in progress.
    Aug 2004
    Wow that looks like a pretty classy solution... Programming in my free time would make my head expload though! I was going to do an OBDII software solution for my senior project in school before until i was forced to do otherwise! -- i like the idea of a standard oo interface!
    VENDOR - OBDPros
    Mar 2006
    Also check out
    http://www.qcontinuum.org/obdgauge/
    This app comes with source so you can see one way to implement an obd II app.
    Paul
    www.obdpros.com
    Low Bitrate sinclairvital's Avatar
    Jun 2005
    Bluetooth Option
