Results 1 to 10 of 11
Thread: OBD-II for a newbie
    Newbie Jenyus425's Avatar
    Sep 2007
    Sonora, CA
    OBD-II for a newbie
    This is probably a dumb question but i cannot find the answer on the forums. I have an OBD-II to serial cable. Do i need a scanner to be between the OBDII cable and serial port of the computer? or can i just plug it straight in to the pc?
    Low Bitrate TonyWare's Avatar
    Jun 2007
    Ottawa Canada
    First of all there are no dumb questions. Second, yes, plug it in. Third... look for software.
    Sep 2007
    NY
    Is there an ODBII to usb cable around?
    Constant Bitrate joeyoravec's Avatar
    Oct 2005
    Livonia, MI
    Quote Originally Posted by Jenyus425 View Post
    Vehicles have special networks (CAN, K-Line, J1850, etc.) which aren't the same as serial, usb, ethernet, or anything on standard laptop. At a minimum there will be some electronics to convert the voltage, but usually quite a bit more. They might be in an adapter-box, they might even be hidden in the shell of the connector, but the electronics definitely need to be somewhere.
    Companies use 9-pin connectors because they're cheap -- it doesn't necessarily mean that you should plug the cable directly into a serial port. The best idea is to telephone the company that sold you the cable.
    Quote Originally Posted by joeyoravec View Post
    Yup I second that! The cable may actually short circuit the serial port on your laptop and cause it to fuxxor up! So don't plug it in, as it most likely does need a scanner! What I think you bought was the cable that goes from car to Elmscan5 scanner.
    Jun 2007
    Ottawa Canada
    Oooops, sorry, thought he said he had a scanner with a serial cable.
    Sep 2007
    Sonora, CA
    okay thanks! so, would you guys recommend a certain brand of scanner? one thats cheap, preferably.
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    I think it'd be best to show us what you have first, what brand, from who?
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
    VENDOR - OBDPros
    Mar 2006
    There are a number of PC based scantools available, one that we make can be seen at www.obdpros.com. Supports all protocols found on vehicles after 1996. 100% compatible with the tons of OBD II software out there for the ELM chip sets.
    Paul
    www.obdpros.com
    Sep 2007
    Sonora, CA
    Quote Originally Posted by muldrick View Post
    not sure. i got it on ebay for like $8.00
  1. Need help to figure out OBD ii connections
    By virengoyal in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-19-2009, 06:03 AM
  2. OBD II and Citroen Xsara
    By ThePohorc in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-02-2008, 09:41 AM
  3. Confused about OBD II
    By tom2112 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-19-2007, 02:06 AM
  4. does this connector means i have obd II ? (Buick 95')
    By tomer in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 09-03-2007, 08:03 AM
  5. Newbie question about ODB I and II
    By Nokia6600 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-24-2004, 11:59 PM
