wow cool as, ok so to view these 'Accelerometers' on the PC, what kinda
software would I require? I'm a total n00b to all of this so all the jiberish wording they use makes no sense to me. I would most likely go for a predone unit, am I spossed to aim at a G force max limit as close to the application as possible for a better reading?
At this point in time my car isn't going to be that fantastic, I just want to have this kinda stuff open for the future. Would my car have OBD1? how would I access it? or is the only solution to access my rpm, speed etc through a aftermarket ECU?
I want to if I can keep all the info in one program, but if I'm running an aftermarket ECU and that Accelerometer through the PC, obviously you are going to need some kind of custom 'front end' to incorporate it all. Is it possible to do it some other way?
I'd rather spend the extra money to make it universal however since I believe the hr31 and the r31 ECU's are different, and therefor I'm guessing the OBD1 is different (if it has one).
So yeah, thanks for the link, its great to see that theres such a easy solution (well it looks easy, but looks can be deceiving :P). Does anyone have any other solutions? Like perhaps a aftermarket ecu with some kinda of input which can incorporate an additional sensor. I don't know too much about aftermarket ECU's aswell to be honest, i thought they all had extra inputs so that u can add features. Or perhaps just adding a software side to the ECU which calculates the G forces by mathematical means.
thanks for the input shotgunefx
~Danz
