Results 1 to 4 of 4
Thread: I want to interface to my 07 Navigator's CAN BUS.
    Oct 2007
    I want to interface to my 07 Navigator's CAN BUS. It has Nav. so it has a touch screen and plenty of buttons to choose from. I want to be able to program the courtesy lights in the mirrors to come on when I push a combination of buttons. I also want to interface lights (LEDs) and other devices onto the bus but I know I need an interface module etc.
    Also some way to talk to the bus, an ELM?... or some other interface software and Ford's protocol. Can anyone out there hook me up?
    Aug 2007
    Detroit, MI
    I would recommend a J2534 compliant device (the Mongoose from Drew Technologies http://www.drewtech.com/products/mongooseiso.html or the ValueCAN from Intrepid Control Systems http://intrepidcs.com/catalog/produc...products_id/35). These handle throughput and filtering quite well.
    As for software, I would recommend looking at the Cardix programming platform (http://ipsecostelematics.dnsalias.net/Cardix/) and the reverse-engineering tool that comes with it to investigate how to sense and actuate the things you mention (to the extent that they are on the CAN bus).
    Oct 2007
    Ok, I have an Elm-5 do you feel the Mongoose will do a better job fro this application?
    I'll get one and try the software.
    Aug 2007
    Detroit, MI
    The ELM device is good for request/response data (which is the case for OBD data), and marginally useful for watching low-rate broadcast data, but it is not well suited for watching high rate traffic and has limitations in filtering.
    So yes, for what you are doing, I would recommend the Mongoose or the ValueCAN (Mongoose ISO/CAN is nominally a better deal than ValueCAN as it's roughly the same price but gives you ISO protocol support in addition to CAN).
  1. New FM USB module, maybe good for our carputers?
    By skywise in forum Road Runner
    Last Post: 01-04-2011, 09:44 PM
  2. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  3. I want to interface to my 07 Navigator's CAN BUS
    By FinMan in forum Input Devices
    Last Post: 10-12-2007, 11:04 AM
  4. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  5. News on the 07 version
    By netsuo in forum NeoCar Media Center
    Last Post: 11-06-2004, 10:01 PM
