Results 1 to 4 of 4
Thread: Do I have OBD?? High Res Pics incl!
    Hi Guys,
    Just got a new car and figuring out whether I should integrate a CarPC into it or not. One of the major features I want from my CarPC is Onboard Diagnostics.
    I have a fairly recent car, a 1999 Peugeot 306 2.0 Turbo Diesel. The best part is, the engine and ECU were actually from a newer car, the Peugeot 307 which appeared in 2002!
    The question now, do I actually have a OBDport?? I have located what appears to be a diagnostics port of some sort, underneath the steering wheel next to all the fuses! I have felt behind the port and there is a THICK bundle of wires coming out, so I am pretty sure I have found it!
    Now all I need are a few guys to tell me what specification it actually is and for the time being, will it work with a ScanGuage II??
    Also, are there any other standalone OBD Scanners like the Scan Guage?
    Thanks for the help guys!
    Ooops! Just saw the FAQ. I do have OBD, infact its ISO 9141!
    Now all I need are a few guys to tell me, will it work with a ScanGuage II??
    Variable Bitrate 307SW_NLD's Avatar
    Apr 2005
    The Netherlands
    I did own a 2003 307SW 1.9 diesel. I have tried using ELM323 and mObydic with little success. Check www.scantool.net and look for supported cars. The connector is a OBD2 port but it seems that peugeot does not have the signal enabled on the connector (maybe your local dealer can tell you more)
    My car: 2009 MAZDA CX-9 3.7L V6 runnin on LPG (Liquid Petrol Gas)
    Hardware: None at the moment
    Software: None at the moment
    See: Velleman K8055 Plugin for Road Runner
    Progress: [XXXXXXXXXX] 0 % DONE
    VENDOR - OBDPros
    Mar 2006
    for standalone OBD II devices, if you only need DTC info you can get them at harbor freight www.harborfreight.com
    Paul
    www.obdpros.com
  1. Replies: 7
    Last Post: 09-03-2007, 08:46 PM
  2. 1995 Suzuki GSX-R 750 FINISHED! PICS PICS PICS!!!
    By xdjxklusivex in forum Off Topic
    Last Post: 01-08-2007, 06:16 PM
  3. Tidder's Suncrap Whoring
    By kamikaze2112 in forum Off Topic
    Last Post: 09-07-2006, 01:07 AM
  4. I'm dating a deaf chick
    By Grayscale in forum Off Topic
    Last Post: 02-22-2006, 05:47 PM
  5. WTB: High res 8.4 lcd 150 nits...
    By spyhunter in forum Classified Archive
    Last Post: 06-12-2003, 10:30 PM
