Results 1 to 3 of 3
Thread: Problems with the OBD-II ElmScan tool?
    Low Bitrate ABTsportsline's Avatar
    Oct 2005
    Seattle
    Anyone else installed one of these in their car? I have the Infill G4 and the Elmscan tool, have installed all drivers properly, have no conflicts on the device manager, yet the program (and streetdeck) both cannot "see" the OBD-II dongle.... it is plugged in through USB (as instructed), yet the software is looking for a com port.
    how did anyone else get this to work?
    thanks!
    Aug 2007
    Quote Originally Posted by ABTsportsline View Post
    thanks!
    After plugging the usb device, check in the device manager under communication ports to see if a new device has been added and its associated com port. I know for a fact that the tool I use to log (and flash) my vehicle (Ford) essentially has a serial to usb adapter in it and I can see it when windows loads up the drivers.
    Nov 2007
    the usb portg will assign a com port to the cable look in device manager under ports and you'll see a new port mine went to com 4 and I have only 1 other port com 1 I use com 4
  1. Need help to figure out OBD ii connections
    By virengoyal in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-19-2009, 05:03 AM
  2. OBD II and Citroen Xsara
    By ThePohorc in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-02-2008, 08:41 AM
  3. Confused about OBD II
    By tom2112 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-19-2007, 01:06 AM
  4. OBD II to USB...
    By sgtpepperaut in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 03-28-2007, 10:45 PM
  5. Replies: 23
    Last Post: 06-21-2004, 08:15 PM
