Results 1 to 9 of 9
Thread: Volkswagen Jetta Monitoring
    Sep 2007
    Canada - Laval
    Hello,
    i have a jetta 1997, want to monitor it, not sure if its OBDII that i need ??
    can any1 tell me if its ok and where to buy that is not to high in price
    running RR on a 10.4 TS
    thanks
    doc
    Variable Bitrate anky1's Avatar
    Apr 2005
    NJ
    docfear, your best bet is to go with vag-com check out VWVortex.com for TONS of info on Vag-com and Ross-tech.com for even more info on the actual software.
    RIP 1993 civic sedan
    RIP 1993 civic Del Sol
    Hello! VW Golf 1.8t
    Sep 2007
    Canada - Laval
    can you give me any direct links for what i need, i went to both sites and i got lost very quick, to many cables and adapters.
    thanks again for the quick reply
    Doc
    Mar 2004
    Vancouver, BC, Canada
    Only Ross-Tech cables work with the full version of VAG-COM. All of the cheap cables you find will only work with old versions that are out of date or the shareware version.
    http://www.ross-tech.com/Merchant2/m...ry_Code=VAGCOM
    Either get a HEX-COM or USB or a KEY-COM or USB, you don't need CAN since your car doesn't support it. Only VWs after 2002 use CAN.
    VENDOR - OBDPros
    Mar 2006
    If all you are looking for is monitoring standard OBD II available pids take a look at www.obdpros.com
    Paul
    Apr 2005
    NJ
    Quote Originally Posted by michbound View Post
    Paul
    Well, although you are right, for an extra 120$ he will get ALOT more functionality, as well as the ability to scan other friends VW/Audis for them.
    Either would work for his needs but he might become unhappy with the generic software at some point. Just looking out for a fellow dubber.
    Hello! VW Golf 1.8t
    VENDOR - OBDPros
    Mar 2006
    Quote Originally Posted by anky1 View Post
    Anky,
    No arguments there, I agree if you have the extra bucks you will get a lot more functionality for the VW specific pid's via a ross-tech scantool
    Paul
    It's not really that small...No, seriously. judoGTI's Avatar
    Feb 2004
    Florida
    The Ross-Tech VAGCOM is the defacto VW monitoring tool. I highly recommend it. The company has good people too so if you run into trouble they are more than willing to help.
    '02 GTI
    [Routis '04] [Opus 90W] [160GB Maxtor HD]
    [Lilliput 7" TS] [VIA M10000] [XMPCR]
    [512MB RAM] [Custom housing]
    [Deluo GPS Mouse] [E-MU 0404 Soundcard]
    Progress Meter: [==============|] 99.9%
    Low Bitrate 20mg's Avatar
    Oct 2007
    chico ca
    i was just gonna look into this for my 01 vw golf. if i find anything useful ill post for ya guys.
  1. 1991 Volkswagen Jetta carpc
    By peecee in forum Worklogs
    Last Post: 10-03-2006, 10:40 PM
  2. 1984 Volkswagen Jetta [FIN] +images...
    By AMDJetta in forum Worklogs
    Last Post: 11-22-2005, 02:58 PM
  3. Volkswagen Jetta 2.0 Battery
    By ghettz in forum Car Audio
    Last Post: 10-18-2005, 04:37 PM
  4. Volkswagen jetta alternator
    Last Post: 10-14-2005, 07:24 PM
  5. Digital 2k2 Jetta
    By ppgt94 in forum Show off your project
    Last Post: 02-20-2003, 03:42 PM
