Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: CHEAP $15 OBD-II scanner!
  1. #11
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    Quote Originally Posted by It's A Honda View Post
    its encouraging to know that it is fast but would you be able to give me an approximate number in hertz "Hz" or times per second ? You could give me an idea for either one pid or several pids.
    The thing is that I already have an interface and I need to log 4 pids at a time to make a timing map, and that interface doesn't refresh that fast, so the information you can provide will really help me determine if it would be worth the effort to go after this one or not.
    Thanks!
    I will get a screen capture tomorrow while I am at the shop.
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
  2. #12
    Jul 2006
    Thanks, will be waiting eagerly for whatever info you can provide in this respect.
  3. #13
    Jan 2008
    I wonder if he will come out with a elm327 version
  4. #14
    Dec 2006
    India
    Quote Originally Posted by mstbone67a View Post
    Please find it at http://www.obddiag.net/multiadapter.html
  5. #15
    Jan 2008
    Well not completely ELM327 since it's missing the CAN protocols I am sure he will get those added soon I imagine.
    Moreover kit's priced at $ 40 plus add time of building it plus cables plus enclosures etc will put you in the ballpark of other ELM solutions.
    I agree that for the adventurous and electronics hobbiest it would be a good project to work on and having more options is always good...
    Mike
  6. #16
    Newbie zerocover's Avatar
    Jan 2004
    NJ
    Dam need CAN!!
    I imagine it should be easy enough to get a PIC to read CAN code.
  7. #17
    May 2005
    Lawrenceville GA
    I just want to know what speed (refresh rate) are you getting ? i.e. if you are querying one sensor then how many times per second(Hz) does it refresh ?
    This is what I am getting. It jumps around a bit. This is with all PIDS being monitored.
  8. #18
    Jul 2006
    Hi,
    thanks for posting.
    Thats interesting. What protocol (ISO, VPW, CAN..?) is it connecting ?
    If you try a software that allows you to set the timeout (I use wOBD) then I bet you will get better speed than that.
  9. #19
    May 2005
    Lawrenceville GA
    Hi,
    thanks for posting.
    VPW protocol
    I will try that software and let you know.
