Results 1 to 10 of 19
Thread: CHEAP $15 OBD-II scanner!
    Aug 2006
    check out this from hackaday: http://www.hackaday.com/2007/11/07/i...d-2-interface/
    some guy built his own OBD-II scanner and shows you the basics on how to build it, or he can ship you a development board for around $6 (you still have to assemble however.)
    FLAC WuNgUn's Avatar
    Sep 2007
    Cool...looks like you need to program the PIC though...
    Aug 2006
    well you could if you want to, the software is available on the website above, but the gentleman is kind enough to offer pre programed chips also. i think its 8 dollars.
    Jul 2006
    very interesting - it is actually http://www.obddiag.net/index.html . The website details everything very well. Should be very easy to get one up and running pretty quickly!
    I wonder what the difference is between this and a typical $100 ELM type OBD2 reader ?
    I am also curious what the refresh rate of this reader is ? Looks promising...
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    I ordered one of these from this guy and it works great on most of the protocols. It is quick and accurate with all of the software he has linked on his site. I even tried it with some other software and it works. If anyone has specific questions about it I will try to answer.
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by fixerofallthing View Post
    Does the kit include the OBD2 adapter or it is separate you have to order from mouser/digikey?
    I guess you have to email him for order cuz I can't find an order link.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Jul 2006
    I just want to know what speed (refresh rate) are you getting ? i.e. if you are querying one sensor then how many times per second(Hz) does it refresh ?
    May 2005
    Lawrenceville GA
    Quote Originally Posted by MatrixPC View Post
    I had to order the cable seperate. From the link on his site. I have been emailing him for quite awhile and when he was ready to sell the kit he emailed me to announce the availability.
    May 2005
    Lawrenceville GA
    Quote Originally Posted by It's A Honda View Post
    The different software allows you to query single or multiple PIDS. The fewer the PIDS the faster the refresh. If only one PID is selected then it is so fast it looks like real time changes, especially if you are looking at a PID that is easy to change like the TPS or RPM.
    Jul 2006
    its encouraging to know that it is fast but would you be able to give me an approximate number in hertz "Hz" or times per second ? You could give me an idea for either one pid or several pids.
    The thing is that I already have an interface and I need to log 4 pids at a time to make a timing map, and that interface doesn't refresh that fast, so the information you can provide will really help me determine if it would be worth the effort to go after this one or not.
    Thanks!
