Results 1 to 3 of 3
Thread: official Ford Diagnostic tool
    Nov 2007
    Hello every one:
    I have a file that I saved from Ford Diagnostic tool. Itís including logging data of sensors (e.g. ABS)
    The file extension is DDL. Does any one know how to open the file? .Any reader software?
    The file attached to this message!
    Thank a lot
    Attached Files Attached Files
    FLAC WuNgUn's Avatar
    Sep 2007
    I opened the file with notepad and saw this at the top...
    Engine Gear commanded by moduleP
    GEAR_HelpDescPCMGEARINT
    SBDS_CONV_643
    SBDS_CONV_285 {1, 2, 3, 4}MODE #VSCPGear commanded by moduleGEAR # \
    Mar 2007
    Rutherford, Australia
    Ah. DDL files are time-based Datalogger Files from the IDS that show the results of continuous requests for certain PIDS. The IDS can record a few seconds of data at a time, or be configured to start logging by a trigger 'event' such as a certain PID going into a certain range.
    I tried to open that file by associating it with one of my sessions (rename the file) and opening it. I'm a little new to this part of the IDS, so the fact that it came up with no data could just as well be me.
    Most of this stuff is not ASCII, so that fact that we see anything at all in wordpad is because some of it is ASCII. So a Hex editor might show more info.
    GEAR is PID 0x11B3 and appears in this instance to be read from the PCM (as opposed to some cars that have a separate TCM for the Transmission - like the ZF 6-Speed Gearboxes).
    SBDS_CONV_643 and SBDS_CONV_285 are scaling/offset converters. A value of 2 = 1st gear, 4 = 2nd gear, 6 = 3rd gear etc
    There is more ASCII in that file though. Enough to see the PID and Scaling used for each. Further down I see:
    GEAR_MAX_HelpDescPCM
    GEAR_MAXNONE
    CV_INT_1_2NumberNUMVSCPHighest Gear Allowed
    O2S1_HelpDescPCM
    O2S11VoltsNONE
    SBDS_CONV_406 VoltageVOLTVSCP3Heated Exhaust Gas Oxygen Sensor (bank 1, sensor 1)O2S11
    RPMDES_HelpDescPCMDSD_EECVNONECV_RPM_MULT_16R PMRPMVSCPDesired Idle Speed %h(RPM)RPMDSD
    TR_HelpDescPCMTRModeNONE
    CV_C170_TR{Man1, Man2, D, OD, P/N...}MODEVSCPTransmission range
    TSS_HelpDescPCMTSSRPMNONE CV_RPM_1_4_0RPMRPMVSCPTurbine Shaft SpeedTSS
    ISS_HelpDescPCM ISS_RPMNONE CV_RPM_1_4_0RPMRPMVSCPInput shaft speed TSS/ISS
    VSS_HelpDescPCMVSSNONE
    CV_VSS_NEWSpeedSPDVSCP
    Vehicle SpeedVSS
    Fault_HelpDescPCM VSS FAULTNONE SBDS_CONV_88{No Fault, Yes Fault}FAULTVSCP"Vehicle speed sensor signal statusVSS_FM
    Lukeyson
  1. BMW E36 : OBD 1 - Diagnostic Tool, anyone speaks German ?
    By jpuype in forum Hardware Development
    Last Post: 11-03-2007, 02:41 PM
  2. Some dick tried to scam me with Tool tickets
    By Goofus in forum Off Topic
    Last Post: 01-24-2007, 12:52 AM
  3. FS Ford OEM stereo AUX input connector unit
    By Dave One in forum Classified Archive
    Last Post: 08-17-2006, 02:49 AM
  4. Question...Jaguar, Daimler, Ford...
    By RoyN in forum Off Topic
    Last Post: 12-30-2005, 04:25 PM
  5. Can I reuse my diagnostic tool?
    By ST34LTH in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 07-07-2004, 05:12 PM
