hello, i`ve just bought a infill g4 din2 carputer.
and wanted to plug in the obd2 to the infill..
how is this done, is it a obd2 - usb plug, or what to do?
best regards from a newbie at obd2...
thank you..
Printable View
thank you..
Yes, you would need a OBD to USB box that would plug into the OBD II port on one side and the usb port into your infill.
We sell one @ www.obdpros.com, and there are also other scantools based on the ELM 327 that would also work.
Paul
www.obdpros.com
would any of the ones based on the ELM 327 with usb work the same?
Yep works similarly, but more expensive :)
Paul
www.obdpros.com
