Originally Posted by
Lukeyson
OK, I've sniffed the messages from a Bosch 8.0 Module on a 2004 Australian Ford. This module has ABS, Traction Control and Stability Control all activated, but not Hill Descent. (Psst, someone from Bosch, help me figure out how to turn this on would ya....!)
The Bosch uses ECU state 87 to allow the activation of a Mode $31 Diagnostic Routine 71. The first byte provided in a 2-byte field determines which wheel the system opens up for fluid (I think), and the 2nd byte determines whether to activate the ABS pump.
It seems likely to me that there might be lots of other options in this 2-byte field.
I also know that Diagnostic Routine 74 gives me access to the steering angle calibration. I wonder how many more useable routines there are? It sure would be nice to know what ALL the Bosch diagnostic routines do.
I plan to run the same test on a Bosch 5.3 Module (Where diagnostics use ISO9141 rather than CAN) and see if the messages are similar.
Lukeyson
