Any Idea?
Luca
What hardware should I buy for my land rover discovery II TD5 registered in May 2002?
I Prefear a USB connection!
Thank you
Luca
Any Idea?
Luca
I'm afraid the situation is as we discussed on e-mail Luca, very limited options.
Faultmate MSV is one, as per other post on this forum.
Good luck in your hunt.
Gareth
UKOBD
Would the low-cost J2534 devices on the market suffice (e.g. Mongoose from http://www.drewtech.com/products/mongoose.html, ValueCAN from http://intrepidcs.com/catalog/produc...products_id/35)? I believe they will work with european cars -- i.e. w.r.t. a J1962 connector and typically supported vehicle networks -- but I don't know that for sure).
I'm afraid not as the pass-thru type devices only work on OBD2/EOBD compliant vehicles.
EU regulations only required diesel vehicles to be compliant from 2004.
Gareth
UKOBD
