Page 2 of 7 FirstFirst 1234567 LastLast
Results 11 to 20 of 67
Thread: Bought a ELM 327 and it doesnt work!!!
  1. #11
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Quote Originally Posted by michbound View Post
    The Dodge is most likely ISO9141 or VPW but the link you provided does say that it supports those protocols, I would try what NiSlo recommended and also try connectibg using hyperterminal just to eliminate additional variables initially
    Paul
    www.obdpros.com
    VPW IIRC...............
    Leonardo Da Vinci
  2. #12
    Variable Bitrate AllThingsEnd's Avatar
    Jan 2006
    Ft. Bliss, TX
    hey hijack, did you ever get this to work? ive been wanting to buy a OBDII interface for my truck.
    [::::::::::] 100% - Planning
    [::::::::::] 80% - Computer
    [::::::::::] 0% - Fabbing
    CarPC:
    SP13000 / 120GB SATA 2.5" / 512MB DDR
    8" Innovatek TS / Globalsat BU-353 / Engenius EUB-362 EXT
    Slot load DVDRW / PS3 Wireless Keyboard
  3. #13
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Not yet, right now my car PC is in pieces (upgrading the power supply) and since the OPUS 320 is so large, I have to customize the case to install it. Tomorrow I will be putting it back together and the first thing Im doing is trying the scanner again.
  4. #14
    Jan 2008
    Hello Guys,
    I bought ELM 327 unit . I received the cd damaged. I can not install it without the driver. can any one tell me how to solve this issue. Please if any one has the driver cd to e mail me the drivers at b_al_dhany@hotmail.com.
    Thank you
  5. #15
    Jul 2007
    Miami
    Quote Originally Posted by Bibo60 View Post
    Hello Guys,
    Thank you
    which unit did you buy though? the same as mine? did it come from hong kong? if yes I can let you down load it from my FTP site.
  6. #16
    Jan 2008
    Thank you
    Thank you very much , it is same like yours, Just instruct me how to download it. Thank you again,
    Bush
  7. #17
    Jan 2008
    Thank you
    Hello HiJack
    I got the driver, installed it, now my computer says "your hardware installed and ready to use". When I hook the unit to the car and start the scan software the software does not see the interface. It says , interface is not responding. I set the com port properly. any Idea?
  8. #18
    Feb 2008
    Have you turned the ignition on or you can just start the engine.
    I had the same problem initially.
  9. #19
    Feb 2007
    bump* I too am looking for this driver.. can anyone help me out?
  10. #20
    Jul 2007
    Miami
    Hello HiJack
    After that Im am not sure..... I have removed my CarPC for a major redo (the first install was unorganized and flawed)..... I got to the same point you did, it installed but had issues connecting.... Some1 mentioned it may be com port and or the baud rate. I notice with the software, it only goes up to com port 5 so I would set the ELM to one of those..... I think the baud rate should 38400 or something.....
    I have it on my FTP. As soon as I get home, i'll post the link, username and password.
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
