Page 4 of 7 FirstFirst 1234567 LastLast
Results 31 to 40 of 67
Thread: Bought a ELM 327 and it doesnt work!!!
  1. #31
    Jul 2008
    Angry
    my ELM is gitting closer to the skip!!!!!!!!!!
    still no joy with it com1 to 9 still not working
  2. #32
    Mar 2008
    Quote Originally Posted by pjw View Post
    Teetr: did you get your interface working ?
    Yes I got it working, it only works when connected to both the car and the computer.
  3. #33
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    That's another thing, make sure your ELM is connected to the computer AND car, and your ignition is on, otherwise it may not work.
  4. #34
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Quote Originally Posted by malcom2073 View Post
    I thought that was self explanitory...........
    Oh well, never assume i guess.........
    Leonardo Da Vinci
  5. #35
    pjw
    pjw is offline
    Jul 2008
    Can you open up hyperterminal or some other serial prgoram and connect? If you press the enter key, it should display either "Elm v1.2 compatable" or something similar then a >. If not, you could be on the wrong COM port.
    Is your interface Serial or USB (Virtual serial port)?
    For my understanding: should the ELM be connected to the car if I try the hyperterm trick ?
  6. #36
    May 2007
    Yes.
    Good grief........
    Leonardo Da Vinci
  7. #37
    Jun 2004
    Westminster, MD
    Quote Originally Posted by greatwhite View Post
    I actually tried connecting to the ELM327 without it being connected to the car the first time. This is possible if it is a USB unit if it is wired for power off USB... but most of them are powered off the cars OBD port instead. Only took me two tries before I plugged it into the car and then it worked
  8. #38
    pjw
    pjw is offline
    Jul 2008
    Yes.
    Good grief........
    Sorry .....
    This one was just to be sure :-)
    Thanx;
  9. #39
    pjw
    pjw is offline
    Jul 2008
    It seems my unit get's power both way's ......
    Connected to the car the powerled is much stronger although
    I doubt if it is a real powerled because sometimes when making
    ignition the led dies for a short while. At that time TX-OBD is
    flashing so I have car communication.
  10. #40
    May 2007
    Elm 327 based units are powered from the vehicle's OBDII connector............
    http://www.auterraweb.com/obdiipinout.html
    Leonardo Da Vinci
