Seems like wrong comm settings;
Have a look at the comportguide that comes with the ftdi drivers or look at:
http://ess.myvnc.com:8928/DISK%201/V...MPortGuide.htm
hi all i have tried all of the tricks advice just give couple of flash and thats it I have tried HyperTerminal and that just looks at me or I get some writing which is unreadable to looks a bit like this ( < ^*> ) so iam total lost and still need a map help o yes I have two of these and they do the same nothing thanks for reading .![]()
HAHAHAHAHHAHAHA.... OMFG, the device is made to scan the car, of course its not gonna work if its not connected to it. I feel you great white......
So is this why most of you are having issues? Well i guess i was unlucky with my unit. The new one works perfect. Although some of the percentages seem off, like engine load is at 1004% when idling, that doesnt sound right, lol.
HiJackZX1 w/ The Tobiathin Core PC system!
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
Starting Raspberry Pi multizone project.
That the device is functionally not working when disconnected from the car is clear :-)
That the device is technically not working is only due to the missing powerline (The
+12V on pin 16 of the OBD2 connector). I guess that if you apply this power the hyperterm trick does work because the device is nothing more than some kind of modem between the car and your pc and as you know a modem does function technically well without a phone line (and responds to the at commands) ......
Leonardo Da Vinci
Leonardo Da Vinci
Ok; You may got me there .... :-)
I have a Honda (Acura) Integra Type-R from '98; I know it is OBD2 compliant but the car has not a 16-pin connector but instead of that it has a 3-pin connector.
To Convert the 3-pin to 16-pin I bought a special connector on ebay: http://cgi.benl.ebay.be/HoNDA-3-PINS...QQcmdZViewItem (Scroll down)
As far as I know that should work because the right pin's are connected (Ground, data, +12V); Do you have an opinion about that ?
Aha!
The plot thickens..........
Your integra should be OBDII since it's post 96.
You've got a fair bit of hardware between your computer and the OBDII stream. If you don't have 12v on pin 16, I'd check your adapter and make sure it's making proper contact at both the vehicle connector and the elm 327 scanner connector.
That's seem to be the most likely point of failure..........
Cheers
Leonardo Da Vinci
My ELM 327 v1.2a doesn't have a connection on pin 8.
Only pins connected are 2,4,5,6,7,10,14,15,16
My VAG COM 409.1 doesn't use pin 8 either.
hi all thanks to you all for your help in trying to get my elm 327 to work on my ford galaxy but i have now scraped both the boxs and bought a new vag com 805 and it work as soon as i connected to the car and solved all my problems with the car so good riddance to the elm 327 my advice is to buy a vag com and save your self some head ache thanks for reading kind regards to you all .
