Results 1 to 3 of 3
Thread: Reading Resistance OBD 1
    Jul 2007
    Ok I got a 1990 Mazda 929. I want to monitor most of the engine sensors from a computer. All of the sensors operate by sending resistance to the ECU. I have the splice harness from Mazda's engine signal monitor. I need something that can read most of the 67 sensors in this car. Anything out there that can do it?
    Oct 2006
    Las Vegas
    You want to read the sensors directly? not via serial? If that's what you're saying, a few fusion brains may be able to handle that job.
    Jul 2007
    can it be read through serial??? I have a splice harness and the technical specificaitons for each sensor. instead of connecting a multimeter, reading the resistance of a sensor and then going through the formula just to find out whats the coolant temp. I'd like to just have it at my fingertips . and see whats what so I don't blow my car up.
  1. OBD II connector on an OBD I car
    By HearseNurse in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 03-23-2009, 09:52 AM
  2. Confused about OBD II
    By tom2112 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-19-2007, 01:06 AM
  3. OBD and Citroen from 2003 (Diesel)
    By Mcnovy in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 09-27-2007, 04:04 PM
  4. OBD or special hardware?
    By Jirka Jirout in forum General Hardware Discussion
    Last Post: 03-04-2007, 05:01 AM
  5. Replies: 7
    Last Post: 07-01-2005, 03:29 PM
