Results 1 to 9 of 9
Thread: help: building a digital cluster w/ navigation
    Jan 2008
    i would like to have someone build a digital dash with the added benefit of a navigation. heres an image to help. but instead of having some jerk displayed id like to have navigation in the spot
    here are the gauges i would need to have work.....speedo/tach/fuel/a/f ratios/boost/oil temp and pressure/water temp/volts air temp would be cool to but not needed like the rest of the gauges. am i missing any....if possible id like some of the gauges combined like this
    the a/f and the boost, volts and water, oil temp/pressure. i know sensors would be needed to monitor the data and i can buys those but i have no idea what program to use to interpret the new sensors. if this sounds like something your interested in let me know and we can work on a price. i thank you for all help generated.
    Feb 2006
    Melbourne, Australia
    Hey, that's my design
    I changed it again, but this version ain't to bad - will probably end up doing it for my UTE after all, but I will need to use an OS such as WinCE, which is a fair bit quicker than WinXP/Embedded (hopefully)
    The watermark you see in the AFR/Boost is one I skinned in, it's the Official FPV(Ford Perfomance Vehicles Australia's) logo
    Keep us posted, interesting idea you have.
    F6 Tornado Project Log ; HP Blackbird Watercooled Server
    Beta Tester for Centrafuse and 3dConnexion (No business affiliation with either)
    Jan 2008
    bump...someone must be able to help
    my videos:
    0-130 silly burnout
    Newbie copter's Avatar
    Dec 2007
    Nor★Cal
    Subscribed... I also want to do gauges (boost, egt and diff temps) for my truck.
    _____________________________
    06 BLACKTIE LBZ | GRAYSTONE METALLIC | MBRP 4" | AMP STEPS | KMC DIESELS | TOYO M/T'S | NCT/COGNITO 4-6" | BILSTEIN 5100'S | MAG-HYTEC DIFF COVER | HID'S | PPE XCELLERTOR |
    ______________________________________
    Jan 2008
    where are you located in norcal...i was stationed out there for 3 years at beale afb. yuba city area(45 minutes north of sac town)and plan on heading back to cali shortly.
    my videos:
    0-130 silly burnout
    Dec 2007
    Nor★Cal
    Napa
    Mar 2007
    Rutherford, Australia
    Can someone tell me if the new hi-series Mondeo has a screen in the Cluster like this?
    It sounds like someone will have to put something together.
    I came across one of these not that long ago - which struck me as a useful system for developing a Cluster Replacement system. It even has 2 x CAN bus inputs.
    http://www.applieddata.net/products_VGX.asp
    Then again, I wonder if this is just the basis for Ford Sync?
    http://en.wikipedia.org/wiki/Ford_Sync
    Lukeyson
    Lukeyson
    Feb 2006
    Nice find, Lukey Small and compact, and the ideal thing to drive a digital instrument cluster ok, maybe we need 2 of those, but, at the right price, it will be worthwhile!
    Can you send me your email addy via PM, I redone my PC, and need to set up msn again.
    Kind regards,
    MrBean.
    Jan 2008
    any ideas
    my videos:
    0-130 silly burnout
  1. SDPIF digital Coax into car audio pieces
    By RedGTiVR6 in forum Car Audio
    Last Post: 10-14-2008, 01:06 AM
  2. New Russian GPS (Glosnass) available
    By MobiTekLink in forum GPS
    Last Post: 04-05-2007, 07:48 PM
  3. Replies: 4
    Last Post: 05-06-2002, 03:21 PM
