Results 1 to 10 of 12
Thread: OBDII USB Cable from eBay?
    Aug 2004
    Bundaberg QLD AU
    Ok I have a 2002 Toyota Camry, and i want to get a OBDII cable to connect to my carputer... now on ebay when you search for OBD2 there is plenty of cheap ones... will any OBDII cable work with my Camry? or do i have to get one the specifically supports Toyota?
    Jul 2005
    Michigan
    No any of them will work. Vehicles manufactured after 1996 are required to support OBDII if sold in the USA.
    Jan 2006
    Hey birdie, did you end up getting an OBD-II cable? I just received mine, bought over eBay from a supplier in China. It works great in my 2007 Camry Altise with Centrafuse. A few things don't show up, such as Fuel Pressure, but that's no big deal. I guess my engine probably doesn't output that info through OBD .... or should it?
    Oct 2008
    Fuel pressure is not obligated for OBD2 or EOBD. It may or may not be supported.
    (Incomplete) list of pids: http://en.wikipedia.org/wiki/OBD-II_PIDs
    Low Bitrate capcadetjc's Avatar
    May 2008
    Lubbock, TX
    I also am wanting to get a USB OBDII cable. I drive a 2007 Jeep Wrangler. How do I know if it uses that CAN BUS stuff? Would something like this work?
    http://cgi.ebay.com/ebaymotors/OBD2-...motiveQ5fTools
    My 2007 Jeep Wrangler Worklog
    Oct 2008
    capcadetjc, NO. That's for VW and Audi with a limited version of the VCDS software.
    Check the 16-pin connector in your car. Does it have pin 6 and 14? Then it could be using CAN. Or have somebody with a working set connect to your car and find out which protocol it is. In the USA and Europe CAN is obligated from 1st. January 2008.
    Which country do you live in?
    May 2008
    Lubbock, TX
    I live in the US. I can post a photo of what it is here in a few minutes.
    May 2008
    Lubbock, TX
    Here is a photo of the port.
    Jan 2006
    That's much like my connector, also 16 pins.
    Mar 2006
    I have a Vag Com cable(the one listed above), and would like to use that as a regular OBD2 connector for my dodge dakota. Would the vag come cable work for regular obd2 on my truck?
  1. Xenarc serial to usb? new cable?
    By JCzajka in forum LCD/Display
    Last Post: 01-04-2008, 08:04 PM
  2. Transfering Files with USB cable or Ethernet Cable
    By aamrtin_723 in forum General Hardware Discussion
    Last Post: 02-12-2006, 07:36 AM
  3. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  4. I have a USB cable (A - B), is there an adapter for B to Mini-B (5pin)?
    By mattress in forum General Hardware Discussion
    Last Post: 10-01-2005, 08:48 PM
  5. Want: Logitech mic, sony e. cable, usb hub..
    By CavityCr33p in forum Classified Archive
    Last Post: 08-19-2005, 08:39 AM
