Results 1 to 4 of 4
Thread: cant locate OBD
    Apr 2008
    cant locate OBD
    Hi All
    Please forgive this complete noob for silly question!
    I am based in a India and own a Honda Accord 94 Model CB4 (Japanse made, auto transmission, 4 door, Sedan class) and recently got it screwed by a local Mechanic. The tuning of Auto Transmission has gone crazy and the RPM meter freaks. I referred to a more trained mechanic who said the OBD has to be done for tuning it back.
    Now the problem is he has tried all spots but cant locate the OBD connector. I read over net that its behind Coin/Ash Tray but the mechanic dint find there as well. I am attaching 2 pictures of DashBoard... if anybody could please hep locating OBD connector I would be very grateful.
    Ankit
    May 2008
    This database should help you out:
    http://obdclearinghouse.com/oemdb/
    Nov 2007
    I use http://www.fixexpert.com/wiki/OBD-2+Location to fix any OBD2 port.
    94, seem pre-odb2, but from the site, I see it should be Closed: In front of the shifter, behind the ash try.
    Apr 2008
    Thanks Guys, mine is a RHD and I found DLC on passenger side below Dash. I thought DLC and OBD are 2 different thinks but it seems the only option I have is DLC. However I was not able to find the connector in scanner machine to connect to that 2 Pin DLC. So finally had to use a jumper on DLC and go for a self diagnostic.
    Any hep about convertor for 2 pin to 3 pin for DLC?
  1. OBD II connector on an OBD I car
    By HearseNurse in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 03-23-2009, 10:52 AM
  2. OBD or special hardware?
    By Jirka Jirout in forum General Hardware Discussion
    Last Post: 03-04-2007, 06:01 AM
  3. OBD 1 Diagnostics software?
    By MaleBuffy in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 06-13-2005, 08:05 PM
  4. OBD USB or LPT1 Connectors?
    By Ritalin Kid in forum General Hardware Discussion
    Last Post: 09-19-2003, 11:01 PM
