Results 1 to 2 of 2
Thread: elm 327 won't talk to PCM..........or maybe it's the other way around.......
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    I picked up an elm 327 based reader last year and just got around to trying it today. It's usb and uses the ftdi chip (I had it open already). The PIC is a PIC18 as you would expect. It only has one LED and that flashes as you plug it in and then goes blank.
    I'm using Proscan 5.1.
    I can communicate with the elm as the log shows the proggy sending out the commands and getting the appropriate responses (ie elm 327 v1.2, etc) right up to the point where it transmits 01 01 and then there's no repsonse from (apparently) the vehicle obdII.
    The car is a chrysler 2004 300M, and it uses VPW SAE J 1850.
    Anyone have any ideas how to get the vehicle and elm to "talk nice"?
    Any settings I could be missing?
    Leonardo Da Vinci
    VENDOR - OBDPros
    Mar 2006
    Based on the description looks like it is not an obdpro but anyways...
    Try connecting via hyperterminal and then type in 0100 that should show what pid's are supported maybe 0101 is not a supported pid.
    Paul
  1. Bought a ELM 327 and it doesnt work!!!
    By HiJackZX1 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 03-31-2010, 07:05 AM
  2. Elm 327 emulator
    By StefanVikman in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 03-12-2010, 08:36 AM
  3. Drivers ELM 327 USB
    By Dj-[NRG] in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-20-2009, 10:53 AM
  4. obd2 elm 327 interface?
    By mrcgibb in forum StreetDeck
    Last Post: 04-22-2008, 06:12 PM
  5. ELM 323 or 327?
    By Hoohar in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 01-24-2007, 03:19 PM
