Results 1 to 5 of 5
Thread: P0135 diagnostic code
    May 2008
    Hello member, I'm happy to have joined your site.
    My question is about a P0135 code on a 1997 Lexus LS400 -- should i just go ahead and change the sensor, or am I making a mistake by trusting the OBD II code reader - does anyone have a clue where the fuse for this heater circiut is?
    Mar 2006
    Colorado, but Canadian!
    Moved your thread here since it has nothing to do with the Fusion Brain. Please be careful where you post.
    1.9in x 2.9in -- 47mm x 73mm
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    Replace the sensor
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
    May 2008
    P0135
    Quote Originally Posted by fixerofallthing View Post
    Replace the sensor
    Thanks for the advice-- I'll let you know how it turns out.
    May 2008
    Quote Originally Posted by 2k1Toaster View Post
    Thanks-- I'm new to this site.
  1. GPS/MapPoint VB Source Code
    By stevieg in forum Software & Software Development
    Last Post: 01-28-2011, 04:59 PM
  2. Weird Registration Code and Hardware Code problem
    By lookinco in forum StreetDeck
    Last Post: 09-30-2006, 03:25 AM
  3. Replies: 0
    Last Post: 06-11-2006, 06:49 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
