not an easy answer for this because it will be CAN related so depends on the diagnostic tool your using and the software ELM327 or similar with USB and Vehicle explorer software will interrogate the complete system ( I got a full working copy off eBay ) unfortunately it doesn't work on the older Citroen's but should be good for the C4 2007.
edit:
the software I bought
http://cgi.ebay.co.uk/OBD-DIAGNOSTIC...d=p3286.c0.m14
lexia 3 is what the dealer uses but you could look for the software and it should work with ELM 327
http://shop.ebay.co.uk/?_from=R40&_t...ugeot+Lexia+3+
this stuff is expensive
LinkBack URL
About LinkBacks
. I was afraid that an ELM327 tool won't be sufficient on its own...
