Originally Posted by
techbod
ill try to explain, say your car is KWP2000 ( thats the protocol for engine management ) as said before and works in ASCII or OBDII/EOBD now CAN bus its a protocol on its own so basicly ELM327 has 2 interfaces built into it and works best with USB2 because its a faster network but you can use the serial side but as said by another member it has to be buffered because serial is too slow thats why is has the XON/XOFF and has to be turned on in your device manager if your going to use serial connection,
hopefully this will shed a little light on the subject as this is where people tend to go wrong
