Results 1 to 10 of 20
Thread: FORD ISO9141 - can any OBD2 tools sniff it correctly?
    Mar 2007
    Rutherford, Australia
    Ford seems to have some sort of proprietary implementation of ISO9141 on it's cars.
    My experience is that the ELM and J2534 style tools can send and receive messages on Ford's ISO9141, but they can't be used effectively for sniffing because of the custom way that Ford implement the message length.
    The tools appear to concatenate query and reply messages, thinking they are one message, and error when the message length is too long.
    Has anyone else experienced this or found a way around it? I'd imagine that support for this method would need to be added to the microcode on an ELM for it to work right.
    Lukeyson
    Jun 2008
    Mar 2007
    Interesting link, but not helpful for my specific issue.
    These are Australian Fords, and the German Bosch 5.3 ABS modules, Canadian Airbag Modules and Mexican Bosch Reverse Park Aid Modules all use what appears to be an implementation of ISO9141 that does not conform 100% to the standard - like in the 1st byte format and the Init process.
    It's curious to note that not even that Ford Protocols table shows ISO for Ford. But then I find that a lot - US or European specifications that don't match what Ford builds in Australia.
    Lukeyson
    Jun 2008
    fords in the UK tend to lean toward KPW2000 and ISO was mentioned before but I never seen it,
    the ABS 5.3 Bosch can be probed with a breakout box due to the small size of the cable adapter there are a few ABS systems used here Mecatronic III / Mecatronic III with traction control ( TCS ) and of course Bosch 5.3
    Constant Bitrate joeyoravec's Avatar
    Oct 2005
    Livonia, MI
    Quote Originally Posted by Lukeyson View Post
    You probably need to adjust the P-timers. When there's a delay you use these timers to decide if you got one long message or two separate messages. The timeout is surely faster for non-emissions networks. Don't you have a Mongoose? It's adjustable on there.
    Jun 2008
    Mongoose now that looks interesting ( I googled it ) not available in the UK hmmmm I wonder why as the cash register clicks at the dealers lol
    Mar 2007
    Well, while I do I have a Mongoose, the problem is I don't have two. You see, when I am using J2534 software with the tool (Like Ford Module Programming for example), I need something else to sniff what's going on.....
    Lukeyson
    Mar 2008
    Sydney Australia
    Also with Ford Australia it seems that they sometimes use different Baud rates i.e the AU model uses ISO at a baud rate off 9400
    Jun 2008
    9600 is the lowest speed
    Mar 2007
    The AU has ISO9141?
    I thought it was just J1850PWM (Standard Corporate Protocol) ?
    Lukeyson
