Can you guys please help me??? OBD Renault Clio help needed!
Hello all,
Right, I have spent the last two days trying to find out what type of OBD my 1999 Renault clio 8v spi uses. It is a UK car. It has a 16 pin connection under the ashtray. It has connectors in pins 1,2,10,12,13,16.
I really do not have a clue.
Thanks for reading,
Ben
Not EOBD, almost for sure. EOBD not required for Europe cars...
Quote:
Originally Posted by
madtoonbull
Hello all,
Thanks for reading,
Ben
until 2001.
Do not know what preceeded EOBD2 in Europe/UK. Here in USA it was OBD1.
Sincerely,
MarcW.
The pins listed do not map to those used by OBD II...
malawigold
hi have you managed to find out what obd port is on the clio and what protocol it uses?
so hard telling what the protocol is. Can't access my company's internal web site where a list of European vehicles that were tested are listed so can't look to see if a '99 Clio on it. Since OBD II not required until after IIRC 2001 (for gas, and even later for diesel) vehicles in Europe and I was only interested in testing/verifying OBD/EOBD II compatibility might not have probably didn't even bother testing any '99 Clio unless a contact in Europe had one handy as a personal vehicle. Most cars tested were newer models at dealerships or vehicles were rented or had access to at companies and their fleets of vehicles.
Short answer is I did not find out what protocol is used by '99 Clio.
Sorry.
Sincerely,
MarcW.
And for a Clio 1.2 16V - 2007
what protocol is used ?
it has connectors in pins 1,4,5,6,7,14,15,16
I'm using a CAN interface (MCP2551 - 18F258 - RS232) connected to pins 6 - 14 (CANL - CANH) at 500kbps.
i don't understand the frames recieved
can anyone help me with some info ?
thanks,
Are you trying to interpret Can frames using a scope or...
arameo
thanks,
do you have the frames showing the numbers like:
03 41 0D 12 AA AA AA AA AA
or are you trying to decipher the electrical wave forms?
2007 vehicle probably CAN but Europe/UK like to use 250KBS not 500KBS. 'course, 500KBS it may be. And 11-bit or 29-bit Id.
The J1962 pin descriptions for pins: 1,4,5,6,7,14,15,16
1 = single wire can
4 = chassis ground
5 = signal ground
6 = discretionary (GMLAN HS CAN High)
7 = K Line of ISO 9141-2
14 = discretionary (GMLAN HS CAN Low)
15 = L Line of ISO 9141-2
16 = unswitched vehicle battery positive
Based on pins present in connector I'd say vehicle could use up to 3 protocols: high speed CAN, single wire CAN, and ISO 9141-2.
OBD II commnication is most likely on the high speed CAN bus.
Sincerely,
MarcW.
