kpw2000+ "cant wake ecu" on bmw 320 d se 2003
hi guys,newbie alert,,,,,,,, trying to connect the kpw2000+ software to the bmw but having trouble as it says cant find or wake ecu,have tried all the key positions but still same
any help and guidence on this would be cool
many thanks
mark
is there nobody out there that can help?????????????
on the vw the kwp2000 wont wake the ecu unless the fuse is removed for the dashboard indicators i.e tacho,speedo ,oil warning etc
only problem with this is when the fuse is put back it brings up cel lights
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
