OBD2 is indeed two way (Request/reply type system USUALLY), however you can monitor the bus and pick up messages on one unit that were sent by another unit. Being as your vehicle is 2007 it is likely a CAN controlled car, so an ELM based device would work for you; check out www.obdpros.com
LinkBack URL
About LinkBacks
