Page 8 of 8 FirstFirst 12345678
Results 71 to 76 of 76
Thread: About ebay's ELM327 (szhid seller & others)
  1. #71
    Apr 2010
    I bought a 1.3 version of ELM327 interface from szhid, but kept on refusing to connect to the ECU of my Ssangyong SUV. I strongly believe that the car is OBD compliant (it has a connector below the steering and the agent uses a scanner to reprogram/upgrade) and after a lot of browsing it looks like it uses KWP2000 protocol. The ELM327 has support for this according to its specificiations. What can be the issue? Sine there were few replies says the Scantool.net does not work with cheap ELMs, I will give it a try with some other software during this week end. Appreciate if any of you already know what to do. thank you all.
    /bug
  2. #72
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by 6208 View Post
    /bug
    Throw the cheap ELM scanner away and buy a real one. That should fix all the issues your having!
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
  3. #73
    Oct 2008
    6208, what model year is your car and has it a petrol or a diesel engine?
    In which part of the world do you live? Usa, Europe, japan, Australia, Brazil or anywhere else.
    The presence of the 16-pin connector does not guarantee the car is compliant with any of the EOBD/JOBD/OBD2 rules.
    Does the interface work on other cars?
  4. #74
    Apr 2010
    Quote Originally Posted by p2psmurf View Post
    thank you for the reply. I live in Sri Lanka. The car is a Ssangyong Kyron diesel 2.0L Xdi. It has this connector below the steering column and the agent use a SCAN-100 hand held machine during the service. I got to know that these cars use KWP2000 interface/protocol, though I am not 100% certain of it is in my case. I wasn't able to use it other cars during this week end as I was busy with other things. I will test it as well before returning it to the seller. I do not want to spend a lot of money on the device, so no plans buying an expensive unit yet. Your help is highly appreciated.
  5. #75
    Nov 2010
    Hi,
    I live in france and also have a ssangyong (rodius) .
    Do you finally find a scanner which can erase MIL check ?
    I know the scan 100 is already used but it's too expensive for a simple customer .
    Merci.
  6. #76
    Apr 2010
    No the ELM unit I bought did not work with the SSangyong. It looks like either the protocol or the baud rate was not supported. I can see that it tries to read the data, but the read data has no meaning. I still want a cheap scanner - for not so professional work. Please update if you managed to find one.
  1. Elm327 v1.3 chip released
    By glm in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-18-2008, 06:55 PM
  2. OBD2 / Elm327 Developers - Please Aid
    By thunderfox5 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 06-25-2008, 03:27 PM
  3. ELM327 v1.2 - Anyone tried it?
    By DroStar in forum General Hardware Discussion
    Last Post: 11-12-2007, 04:16 PM
  4. [Vauxhall Astra '99] ELM327 vs Tech2
    By nikione in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 07-14-2007, 07:46 AM
  5. Opinions on screen and seller
    By DJDiggler in forum LCD/Display
    Last Post: 09-26-2004, 09:11 PM
