Results 1 to 10 of 15
Thread: J2534 programming in VB.Net
    Aug 2008
    Hello,
    If this is in the wrong section, please move.
    I'm seeking advice on (you guessed it) programming with a J2534 PassThru adaptor in VB.Net. More specifically, It's a FEPS enabled Ford Mongoose from DrewTech that I want to use to (at the moment) read PIDs from my ECU and then log them into a database. I'm quite confident that I can accomplish adding data to the database, however I cannot do this without being able to request PID data and this is where I'm doing my head in trying to get this to work.
    Using the VB6 source code from the DrewTech website, I can get the program to open the connection to the Mongoose through the DLL and then establish the proper communication settings or at least I think it does because the red light flashes when I connect/disconnect to the device and the green light changes from flashing fast to slow. Though as far as requesting PID data, I'm not having any luck.
    Also, previously I had an ELM 327, however I foolishly tried to extend the OBDII cable using two null modem cables, causing permanent damage to the ELM. I can still read data using PCMSCAN or DataPro with the Mongoose (however I can only get a few PIDs to work, and only slowly), but I want to have my own program do this.
    Here is a link to the program so far:
    www.qantec.net/Downloads/Mongoose.zip
    Sorry for the long post, I want to be as detailed as necessary.
    If anybody could tell me how to request PID data or at least what I'm doing wrong I would be most greatful.
    Stiff
    Edit: forgot to add url for DrewTech VB6 source code
    http://www.qantec.net/Downloads/Drew...SourceCode.zip
    Aug 2008
    UK, yorkshire
    Hello..
    have a read of this http://en.wikipedia.org/wiki/OBD-II_PIDs#Query and
    http://digitaldeviation.com/content/...on-source-code
    good luck, let us know how you get one.
    D
    Nov 2007
    J2534 is not the same as ELM, though.
    Stiff, have a look at http://www.openecu.org/index.php?title=J2534
    It's really sparse, but it's the only thing I know of.
    Aug 2008
    Sorry for the delay, due to time constraints I have decided to use an ELM 327, however I will hopefully be adding support for J2534 devices in the near future.
    For those that are interested, here is a link to my program:
    http://rapidshare.com/files/14677248...rv0.4.exe.html
    Currently your elm needs to be on COM4 for the program to work and you cannot change the serial port settings.
    To connect, click on connection and then connect.
    It will log data by pressing "button2", however that is all it does for right now, no conversion from hexadecimal or displaying of data.
    You can however display data without logging it if you press "button1", a word of warning though - the data you will see will be raw data, no conversion from hexadecimal or kind of formatting.
    I'll try to remember to post back when I get more of it completed.
    Thanks for the help.
    Stiff
    Feb 2006
    Melbourne, Australia
    Heya Stiff,
    A long shot, I know, but did you succeed in adding support for J2534?
    Appreciate your feedback
    F6 Tornado Project Log ; HP Blackbird Watercooled Server
    Beta Tester for Centrafuse and 3dConnexion (No business affiliation with either)
    Aug 2010
    Grand Rapids, Michigan
    J2534 .net library
    Hey guys,
    If you're still trying to use J2534 in .net, I uploaded a library I wrote that simplifies it a little bit. Take a look at the sample code (it's in C#, but feel free to email me if you have any questions).
    https://github.com/mkelly/J2534DotNet
    Jun 2007
    link to drewtech vb6 dead
    Aug 2010
    Quote Originally Posted by planethax View Post
    The sample code with the library I linked to will auto-detect all installed J2534 devices, and includes examples of sending OBD-II commands. I tested it on a DrewTech Mongoose and a Dearborn Group Gryphon.
    Jun 2007
    May need to learn .Net, but everything else I have done is in VB6
    Still looking for the VB6 source
    Constant Bitrate joeyoravec's Avatar
    Oct 2005
    Livonia, MI
    Nothing special... just visit http://www.drewtech.com/downloads/ and download the "J2534-1 Tool". The installer gives you a *.exe and puts the full source code along with it under c:\Program Files. It's a little messy though; you could probably do better yourself once you get the hang of things.
  1. vb.net code for volume control
    By takissd in forum Software & Software Development
    Last Post: 12-27-2008, 05:19 PM
  2. Replies: 0
    Last Post: 07-03-2007, 02:04 PM
  3. Wanting to learn some programming, help me pick a language!
    By RS3RS in forum Software & Software Development
    Last Post: 10-15-2004, 05:38 PM
  4. C++: GUI Programming with >NET Framework
    By [iG] in forum Software & Software Development
    Last Post: 05-24-2004, 07:57 PM
  5. VB.net and FMOD
    By bondbond55 in forum Software & Software Development
    Last Post: 03-12-2004, 11:56 AM
