Results 1 to 5 of 5
Thread: help with elm323
    Sep 2008
    help with elm323
    hi every one hope you can help i have proscan on my laptop running on windows 2000 when conected to car it gives the following mesages.
    the interface hardware was detected and initialized but communication with the vehicle could not be established.
    verrify that the vehicles protocol matches the interface
    system null reference exeption not set to an instance of an object.
    can any one help with this
    Jan 2007
    Szeged, Hungary
    OK, what car do you own?
    What type of interface are you tried?
    Alopecia perniciosa
    VENDOR - OBDPros
    Mar 2006
    Can you connect to the interface via hyperterminal and see if you can send it commands?
    Paul
    www.obdpros.com
    Sep 2008
    hi it is a vauxhall frontera 3.2 Ltd
    Sep 2008
    hi ya not sure how to set up hyper terminal
  1. My ELM323 only works with 'ScanTool'
    By ren_laguna in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-13-2009, 08:36 AM
  2. Building ELM323 interface
    By bes51659 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 07-29-2008, 05:33 PM
  3. OBDII for ELM323
    By hjcho616 in forum Road Runner
    Last Post: 11-29-2007, 10:14 AM
  4. ELM323 and MAX232 ISO interface
    By yossisibi in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-12-2006, 07:19 PM
  5. 2 ELM323 Adapters Brand New $50 w/ serial cable
    By MattJackson86 in forum Classified Archive
    Last Post: 08-30-2006, 11:56 PM
