Results 1 to 10 of 18
Thread: Will A Simple OBD - Serial Port work?
    Newbie Atulsohan's Avatar
    Dec 2008
    India
    Talking Will A Simple OBD - Serial Port work?
    Will an OBD-SERIAL cable Work when plugged into ur com?
    are ther softwars capable of such things
    ie. with out the costly interface
    Oct 2008
    No, you will need an interface circuit.
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    To elaborate on what Rooster said: Not for OBD-II. Some OBD1 interfaces can get by with a couple transistors resistors and diodes, but that depends entirely on what you have.
    Dec 2008
    India
    Question k so tell me abt the transistor
    So can a port interface work with out the costly 500$ interface ; can u build one out of simple transistors on a bread Bord?
    VENDOR - OBDPros
    Mar 2006
    You could even build a cell phone on a bread board if you like the challenge
    Need some more details before any useful info could be provided.
    Mainly what type of a vehicle do you own - OBD II, OBD I?
    For the ISO vehicles it is possible to build a simple level converter that would work with the right software (most of the free software expects an ELM or ELM compatible interface), for the other OBD II protocols such as J1850 and CAN it is not that easy and requires a hardware centric solution
    BTW you do not need to spend $ 500 for a OBD II interface, you can get an OBD II interface for less than $ 85...
    See my sig for one example
    Paul
    www.obdpros.com
    Dec 2008
    India
    will ELM327 USB work?
    HEy guys Thinking of buying an ELM327USB ?
    will it work on all the protocals ?
    wil it accept Fiat ?
    that too a bravo 1.6 16v (Built After 2000)?
    please reply
    Oct 2008
    Atulsohan, next time it would be better to start a new thread.
    But since it's already here I'll try to answer it, but I do need to know the country you live in to just do that.
    Also what is the exact model-year of your car? Built after 2000 could mean 2000 or 2008.
    Dec 2008
    India
    Sorry abt posting it here new to stuff like this;
    MY car is really a Fiat Siena !.6 16v (2002 model)
    the engine is the same as the bravo 1.6 16v
    i quotes after 2000 As there lyes the main differnce in the engine ; u knoe before the exaaust was on the front the cam sensor was on the exaust pully ;etc ....
    the is y i quotes ;
    anyways plz reply
    Oct 2008
    Country?
    Dec 2008
    India
    Red face Sorry
    Sorry abt that Iam From india
  1. bluetooth serial port
    By tundra2000 in forum Wireless Communications
    Last Post: 04-07-2007, 12:32 PM
  2. serial port to game port adapter wiring
    By asif in forum General Hardware Discussion
    Last Post: 08-17-2006, 04:47 PM
  3. need a extra serial or parallel port?
    By Sway in forum Input Devices
    Last Post: 01-08-2004, 06:48 AM
  4. So I cant get my simple LCD to work... :(
    By sirhotalot in forum LCD/Display
    Last Post: 08-16-2002, 10:57 AM
  5. Via Mini-ITX Epia 5000 serial port not working
    By vash in forum General Hardware Discussion
    Last Post: 08-13-2002, 08:48 PM
